Results 1 to 8 of 8
- Aug 2005
- 13
August 29th, 2006 05:12 AM #1my car is a corolla 93 GLi. I noticed my temp gauge seems to go up than normal. I noticed that the only fan moving was the smaller fan (A/C fan). I decided to replace the motor of the bigger engine fan. however, now i noted that when the aircon is turned on, both fans work which is i guess normal. BUT, when you turn off the A/C the bigger engine fan doesn't automatically turn on when the engine reaches a certain temp. hence, my car overheats when the A/C is turned off.
What's the problem?
How to fix it? thanks
- Aug 2006
- 337
August 29th, 2006 10:11 AM #4
i think fafs, ok ang relay niya..kasi pag in-on ang ac, umiikot ang rad fan, eh..
baka ung thermo switch/stat ba un? baka un ang naglock..dapat kasi when the engine reached the desired temp, mag-open un then open niya ang rad fan..parang ganun..sa kin kasi, dati, ayaw umikot ang fan kahit naka-ac..palit relay..un, oki na..off siya pag ala pa sa desired temp ang engine..
- Aug 2006
- 337
- Aug 2005
- 13
August 30th, 2006 06:54 AM #7thanks for the reply. L try to have them check both. hopefully matapos na.
Toyota is my choice
- Aug 2005
- 2,063
August 30th, 2006 09:27 AM #8
