Page 1 of 4 1234 LastLast
Results 1 to 20 of 61
    Guys, saan ba may shop dito sa Metro Manila which has the proper equipment for fully replacing ATF?
    Yung ibang shops kasi all they can do is just drop the pan and replace 3 or so liters (not all of the ATF).
    Papapalitan ko sana yung sa Starex. Any idea how much a service like that costs?
    Salamat.
    si speedyfix yata... na bleed nga nila lahat ng brake fluid ko (including those in the brake lines going to the brake discs).
    Jul 2005
    also read something like that in one of the forums before.......
    and as far as i can remember, totie cruz said that there is this shop which sort of giving your car an atf dialysis......sucking all your atf. even those inside your torque converter.
    i think that is worth 2.5k before............shop name, i forgot.
    I had mine done kay Stage1 Motorworks dyan sa Araneta, drain pati pipes at torque converter, pinababa ko kasi tranny coz of a stupid water jacket behind my flywheel.
  5. #5
    is it possible to drain all the ATF without taking down the tranny?
    Not sure, ang alam ko kasi kailangan hanginan yung mga pipes etc... Akin mga 6.5liters na ATF pinalitan, so mga 95% siguro, 7liters lang kasi lahat-lahat kasya sa AT ko... The last time na drain and replace lang sa gas station 4liters lang ginamit.
    May 2004
    alam ko autotechnika meron. better call them first.
  8. #8
    just a thought, di kaya delikado hanginan yung ATF lines baka magka moisture at magtubig?
    Well, yung gumawa sakin may water separator ang air tank nila kasi.
    Jun 2004
    I read in one of the forums na kaya ito sa Autoplus. P1,500 ata ang labor.
    Aug 2003
    Salamat.
    sa fronte motorparts sa banaue meron, bro. they call it atf "dialysis". just forgot how much the service (atf included) costs.
    Kung 1500 mura nun hehe.
    Nov 2003
    1500 sa autoplus is the labor palang. they have a nice new machine and will be able to suck up everything. figure 6-10 liters of atf so you have a good flush.
    Aug 2006
    Not sure kung torque converter ng stares have drain plug.Kung meron it's very easy.let me know.
    Jun 2006
    Just wondering why you need to flush your entire ATF system. I thought the normal procedure is to drop the pan and replace the 3 or so liters of ATF and replace filter if needed.
    Sa Pilipinas naging 'normal' na iyan kasi wala tayong equipment. hehehe. Pati sa dealer iyan na ang 'normal' nila.
    Jun 2006
    I see. So how often should you drain and replace the system. I know usually every 2 years or 24,000 kms or whatever is stated in the manual. What I'm asking is should ATF "dialysis" be performed every 2 years or every other ATF flush, so in effect one dialysis per 4 years, or is it ok to just do the "normal" replacement?
    Naku sir, intervals depend on your vehicle. Yung sa Starex hindi ko pa nacheck ang intervals. But this will be the first time na papalitan yung fluid since the unit was acquired in 2003.
  19. #19
    sa autotechnika sa fairview, when i asked meron sila....
    Jul 2003
    Saan ang location ng Autoplus?
ATF Replacement
