How frequent and pagpalit ng ATF Fuilds? What is a good brand for ATF Fuilds?
i think you have to check the quality of the fluid. pag masyado maitim na its time to change. consult your manual about the interval.
any ATF with reputable brand will suffice.
hth.
btw, it's a good idea not to mix different brands. drain the old fluid and replace with new just to be sure.
The owners manual usually recommends 40,000km intervals but given our humid, dusty, and rainy conditions, anywhere between 20 to 40K seems good.
On the ATF to use, use one that is specified for your engine (i.e. Dexron II-E, Dexron III, etc). Use a known brand (i.e. Mobil, Castrol, Shell, etc...)
I usually ask the casa what type and brand of ATF they use then source it on my own.
This way you're sure you get the right type, ie, Dexron IIE or III or Mercon V.
Revive ko na lang tong thread kaysa open new one.
May difference ba (aside from price) ang different brands ng ATF with the same specifications? So Dexron III from Shell, Caltex, Petron or Castrol are they equal or will one brand perform better?
What is your prefered brand and how much per liter?
wala available ATF dexron III sa shell, petron and caltex. autosupply and SM ACE hardware sell CASTROL TQ DEXRON III for 220 php. mahal ang MOBIL multi-purpose ATF dexron III, nasa 250 php. TOTAL stations also sell DEXRON III for 150 php only. pare-pareho lang naman sila in terms sa performance coz they are especially meant for ATF requiring dexron III specifications. Go for CASTROL..
May stock niyan sina Glenn. Php220-230/liter ata. Castrol Protector series Dex III. Iyan kasi ginamit ko nung nag-change fluid sa PS ng Vitara.
Nasa profile ni GlennSter ang address at name ng shop nila.
thanks sir Otep,..pag wala ako makita banda dito sa Frisco area .
go na lang talaga doon kina Glenn.asar kasi traffic doon sa Edsa/Kamias
OT: Huwag ka dumaan ng EDSA-Kamias. Mag-elliptical road ka then Kalayaan. Sa dulo ng Kalayaan (cor. Kamias), tindahan na nila.![]()
ay oo nga pala pwede nga pala sa circle ang daan deretcho pa
thanks again Doc
The big 3 have Dexron III ATF.
Shell has 2 variants. Donax TX is full syn Dexron III and Donax TG. No idea how much.
http://www.shell.com/home/Framework?...onax_0326.html
Caltex Dex III ATF was selling for 212 php sa Caltex SLEX northbound. Cant recall the name.
Petron ATF Premium is Dex III, was selling for 178 php sa Petron SLEX southbound.
http://www1.petron.com/fueljourneys/...ans.asp?ID=109
Anyone tried the Total ATF?
Last edited by userfriendly; January 6th, 2007 at 08:27 PM. Reason: additional info
Pag full synthetic Redline ako including engine oil from Superior sa may Panay or Triplex sa may Kamias.
sa petron kamias cor. kalayaan, P153/li yung dextron III compatible na atf nila
So same lang ba ang performance ng mga ito? So kung baga just buy whatever you want. At kung tipid mode just buy the cheapest one and you will still get the same protection for your tranny.
most atf's available locally are mineral based.motul, redline and mobil have full syn variants which will be able to take more abuse.
hindi naman siguro sa mahal or mura magtinda... mahal talaga yung produkto.
