Results 21 to 30 of 35
Tsikot Member Rank 5
- Nov 2003
- 3,849
August 29th, 2006 09:03 AM #21orly_andico, nah... i'm certain they're not obdII compliant pa. mitsus are another matter pero honda didn't start becomming obdII untill the 2001 ES civics. all of the previous cars used the honda 3 prong connector pa. it should be easy enough to check what the problem is by grounding the connector and reading the code.
ronald_m, you're not based in the philippines right? i wouldn't jump to conclusions based on standards of different countries and them apply them right away to the philippines.
August 29th, 2006 09:32 AM #22
I've tried re-setting the ECU by disconnecting the negative terminal of the battery for more than 5 mins., pero the D4 light is still blinking.
Pero before, when this blinked, I just turned off the engine tapos after starting it after 5 mins, di na sya nagbi-blink. Occasionally there were times na after driving for 10 mins, blink ulit. The problem was intermittent, there were days na meron, sometimes wala. For the whole month of July, di nag-blink.
But now, right after starting the engine, blink agad. Siguro pa-check ko muna sa Zee sa Aurora, kesa bumili ako agad ng surplus na tranny
- Aug 2006
- 337
August 31st, 2006 09:17 AM #24
Just searched the net for possible solutions to my problem.
From what I've gathered, most likely Transmission Control Module or TCM ang problema, but according to speedyfix, wala naman daw TCM ang PHDM Hondas. So this leaves me stumped. I've tried to reset the ECU by disconnecting the negative battery terminal for about 5 mins, pero nagbi-blink pa rin.
Yung lock-up clutch kaya? Or control solenoids? Kung may TCM sana, pwedeng i-self-diagnostic.
Also, I've noticed na di na ata gumagana yung VTEC. Before kasi, pagpalo ko ng 3000rpm, ramdam ko na yung pag-change gears at tunog ng VTEC. Now, kahit 3500rpm (~120kmh), walang nangyayari. Parang at D4, di na sya nagsi-shift down, even with the pedal to the floor.
- Nov 2003
- 3,849
August 31st, 2006 09:27 AM #25wait, baka nga tcm yan. alam ko the accords and crv's have them. it's the civics that don't.
you might be pretty hard pressed to find it tho.
you can try to see what the error code of the tranny is by grounding the circuit and reading the number of blinks ng d4 light.
- Aug 2006
- 337
August 31st, 2006 09:59 AM #26USDM 93 accord has tcm. If you have one,This might help you out.Read your D4 blinks.Got this from shop manual.
code 4=Crank Angle or Crankshaft Position Sensor.
code 7=Throttle Angle or Throttle Position Sensor
code 9= #1 Cylinder position sensor
code 14= Electronic Air Control
you might also have a bad tcm. the resistors goes kaput.Last edited by ronald_m; August 31st, 2006 at 10:07 AM.
August 31st, 2006 10:18 AM #27
i'm pretty darn sure a crankshaft sensor, cam sensor, or similar wouldn't have an effect on the tranny shifting. things like the throttle angle and cam sensors would affect idle and high-rpm operation. the air control thingie would affect the idle.
all those codes seem unrelated to the tranny (although they could affect the VTEC like the OP reports).
*galactus, why not go to the casa and have them diagnose it? wala naman sigurong bayad kung di mo ipapagawa sa kanila. definitely whether OBD-I or OBD-II or even non-OBD yan, the casa will have the tool to read it. or baka pwedeng i-DIY (speedyfix prolly knows how to do it.. or pwedeng i-google).
or maybe Zee can have a look at it.
ang alam ko sa US libre magpa-scan ng ECU. ang pinoy nga naman..Last edited by orly_andico; August 31st, 2006 at 10:21 AM.
- Aug 2006
- 337
August 31st, 2006 10:34 AM #28
August 31st, 2006 10:40 AM #29
*ronald_m,
i meant free scanning sa autozone. or rather you can borrow their scanner for free.
ang alam ko the banawe boys repair ECU's and TCM's. but they have no skills, they just blindly replace parts. :P
although one can buy a surplus ECU or TCM for relatively cheap in banawe. the place is awash with ex-Japan ECU's and TCM's for auto trannies. an ECU for an automatic midsize car is like 2000 petot = $40. but for a manual tranny.. 5X that. i think 90% of ex-Japan salvage are automatics.
- Aug 2006
- 337
September 1st, 2006 05:52 AM #30
