Results 21 to 30 of 34
July 16th, 2007 12:24 PM #21
I have that FE in my sammy. Don't put it in the trunk. Install it where you can access it without getting out of the vehicle. Refillable po yun sa handyman may mounting bracket and meter pa siya.
- Nov 2006
- 299
July 16th, 2007 02:33 PM #22additional lang sa basic tools na iyong dadalhin,
test light and most important thing ang safety googles for eye protection.
July 17th, 2007 01:21 PM #23
ratchet and sockets #8, 10, deep 12, 14, 17, deep 21, univ joint, short extension bar
flex rod, adjustable spanner, vise-grip, long nose pliers, work light
cutter, flat and phillips screwdrivers, set of combination wrenches
ewd, long g.i. pipe, wd-40, tire gauge, air compressor, tow cable, jumper cables
gallon of distilled water, motor oil, rags, bulbs, a relay, vacuum hose, jack
torque wrench, tie wire, assorted fuses, clips, screws, nuts, and washers
July 19th, 2007 09:21 PM #24
Usually for long trips, I bring most of these. The big ones, i keep in the trunk.
- cable ties, various sizes
- wrenches 8 - 12
- 8" adjustable wrench
- philips and flat screwdrivers
- 1 liter extra engine oil and ATF, and some brake fluid
- extra fuses
- mech pliers, long nose pliers and wire cutter
- some spare wires and nuts and bolts
- 4 liters tap water and extra container
- lighter, can opener, extra shirt, shorts
- LED flashlight
- towing rope
- 2 ton jack and cross wrench
- basahan, 1 sachet of car shampoo
- jumper cables
- EWD, elect. air pum
- a bottle of betadine, some cotton and bandages
Ano pa ba pdeng i-add?
July 19th, 2007 09:54 PM #25
tyre wrench + 2ton jack
screw driver + / -
plier
long nose
vise grip
fuse
flashlight
engine oil
break fluid
PS fluid
4ltr water
adjustable wrench
nuts/bolts
fanbelt
tester
mga abubot
cable tiesLast edited by VtEC; July 19th, 2007 at 09:58 PM.
August 1st, 2007 11:21 PM #27
-toolkit na nilagay na ng casa, may kasama na first aid kit
-calling card ng tow service (hoping they're still in business if i need to call them)
-early warning device
i'm planning to get the airpump w/ flashlight and pressure gauge in 1 na nakita ko sa ace hardware, may nakabili na ba nito? durable po ba? mabilis po ba mag-inflate ng tire?
thanks
July 7th, 2009 01:44 PM #28
basic tools for tire changing.(freebie)
vice grip, cutter, basahan, small pliers
and
handy feather duster.. hehe
July 7th, 2009 01:45 PM #29
hmmm... dapat pala bumili na ako isang heavy duty na tool box, ang liit ng tool compartment ng innova
- 168
July 8th, 2009 12:04 PM #30EWD
long nose
screw driver
basahan ( some old underwear )
grease
wd40
brake fluid
Varta used as replacement battery in German cars ... but they cost double that of Motolite ... not...
