Results 11 to 20 of 20
November 9th, 2007 10:52 AM #12
8,10,12 and mm. sa 168 mall lang ako bumili ng mga pandagdag as mga Stanleys ni erpat.
November 9th, 2007 10:56 AM #13
^I think he meant hexagonal
Medyo nalalayo na tayo pag ***agonal
Here maraming Stanley, Craftsman, Hazet, etc. Stanley ok na sa akin. Autozone has nice quality tools too - Greatneck yung brand nila. Duralast ones are too expensive for me.
Avoid cheap tools unless you want to strip the fastener. I learned this the hard way - had to buy vice grips to get the screw out.
For sockets, I have 3/8 drive, 1/4 drive sockets with adapter to go from 3/8 to 1/4. I also have sockets with 1/4 instead, to avoid lowering the torque when using the adapter. A torque wrench is good to have too as well as a breaker bar. Just be careful and know the torque specs and corresponding units measurement (lb-ft or otherwise).
November 9th, 2007 12:08 PM #14
yeah that's what i thought. I had to google to be sure
anyway, avoid cheap tools. great investment ang mga ganito. I remember somebody had a bad wound when the wrench broke( the open side). he bought another of the same brand, and it broke again. KYK ata brand nun
- Feb 2006
- 771
November 9th, 2007 02:25 PM #15ayos to!hehehe
salamat po sa mga inputs,mga magkano po kaya per piece ng mga to?
salamt po uli mga sir
November 9th, 2007 08:11 PM #16
There's a good KYK variant (yung Japan)... True, avoid using cheap tools, especially on heavy work as they can break indeed. I keep a set of the cheap tools in our garage for light work (removing small stuff, etc) so it's easy to access and it won't hurt much if ever it's lost or stolen.
November 9th, 2007 10:06 PM #17
November 10th, 2007 01:23 PM #18
ok na ang 10,12,13,14 na box at 10,12,13,14 na open para mag umpisa ka,pero kung maluwag ka sa pera don kana sa mahal na brand para maiwasan mo na mabilog ang bolt & nut.pagmumurahin ang tools mahinang klase ang bakal na ginagamit sa tools kaya madaling masira at baka masaktan ka pag kabyos.try mo ang stanley,husky,craftsman at kung gusto mo ng D'best Snap On ka na. just to start ok ang mura pero ingat ka sa pag gamit.
- Jun 2004
- 103
November 11th, 2007 12:58 PM #19
- Jun 2004
- 103
November 11th, 2007 01:10 PM #20Ok na nga ang sizes 8,10,12,14 for most ordinary work.
But most crankshaft bolts are 19mm (for turning the engine when setting TDC). If you also have to do some undercarriage work (replacing balljoints, engine supports, etc) some of these nuts/bolts are 17mm.
Traffic!
