Results 1 to 10 of 10
July 5th, 2004 11:28 AM #1
i recently bought a second hand local gen2 paj. Since maganda kung everything is new for record keeping purposes, ano kaya recommended specs nyo ng gear oil . Pakispecify naman ng preferred brand. Patulong naman mga bossing! :help!:
- Jun 2004
- 476
July 6th, 2004 02:06 PM #3check the owners manual. the specs are there. as far as i can remember the required specs are:
GL4 rated
SAE 75-90
Hyphoid
i'll double check my owners manual and get back to you later.
most gasoline stations have SAE 90, GL4 gear oils. di lang yata hyphoid gear oil. for my rig i use mobil 1 fully synthetic SAE 75-90, Hyphoid, GL5 (or 6 yata) gear oil.
castrol also has a good gear oil - castrol hypoy (SAE 90, mineral, GL 5 (or 6). you can get this in most reputable car accessory shops. price is around P400/liter last time i checked.
- Nov 2004
- 115
April 20th, 2007 02:13 AM #5I wish to change gear oil.. alin ba ang mga dapat palitan sa Pajero 4d56tdic
- Transmission
- Transfer case
- Front Axle
- Rear Axle
saka saan ba mura?
Tsikot Member Rank 5
- Nov 2003
- 3,848
April 20th, 2007 08:30 AM #6castrol protector series is what i use on my montero for the diff. ok naman.
April 20th, 2007 12:33 PM #7
basta "90" ung nakalagay sa spec, tamag yun, yung "140" msyadong malapot.
- Nov 2004
- 115
October 31st, 2007 07:22 AM #8pwede ba DIY ito? i asked shell about replacing gear oil.. 170 per liter.. but forgot to ask kung hyphoid..
if I buy the oil myself.. madali lang ba palita ito??
thanks.
October 31st, 2007 10:27 PM #9
buhay pa pala thread na ito
Pwede DIY. I've tried it though preferable na may katulong ka para may tumitingin sa ilalim kung umaapaw na yung oil. Ako kasi tagahawak ng hose at tagasalin ng oil sa bandang itaas
Advisable din na medyo malaking hose ang gamitin kasi sa lapot ng oil (SAE 90) ang tagal bago bumaba. Maliit na hose kasi nagamit namin. Buti na lang mahaba ang pasensya nung nandun sa ilalim
- Nov 2003
- 3,848
November 5th, 2007 08:50 AM #10tried out the royal purple max gear. much better than the castrol...
for manual pajeros around 9 liters kung kasama lahat ng diffs and tranny.
China's EV industry concerns. Here's what we know CNBC Television
China cars
