Ano ba ang maganda or tama?
Manual or computerized na camber/caster adjusment, kasi ang ibang model ng sasakyan ay wala sa database ng computer kadalasan
Marami na pong shops ngayon na updated ang database. Meron akong napagawan sa Evangelista dati kaso sa sobrang high tech ng gamit nila, taga din sa price. Nasa bandang dulo na yun away from EDSA.
But I'd still prefer the laser ek ek, computerized thingie.![]()
Computerized din ako. Even if they don't have it on database, at least mas accurate ang measurements nila.
Pero sakin basta diretso takbo at pantay ang kain ng gulong happy na ko.
Mga henyuses. anong shop po ang marerecommend niyo for alignment... yung efficient pero mura lang!!!
Camber adjustment? don't they do this manually since you have to move it by hand and use the computer to check it? Correct me if i'm wrong...
But for wheel alignment, i prefer computerized..mas accurate ata eh
kahit papano computer is still better. i don't have alignment in the shop and when we do major suspension work we always recommend to have the suspension aligned sa labas. we try to do it manually by adjusting it until derecho pero kahit papano di makukuha ng manual adjustment yung kaya ng computerized![]()
I have mine done at Imelda Avenue Marikina = Alpha Performance (Big Yokohama Sign). Pag palit nang balljoint, tie rod etc...sabay align and if needed camber din. Parts = 555!Originally posted by fildeps
pagpalit ng underchassis ea. tierods, balljoints, drag links, etc kay ferdie. pag alignment sa servitek marcos hiway or kay pacleb sa concepcion marikina.
sakin computerized pag chinecheck, pero pag inaalign na, manual na. ganun ba talga? mga 500 lang inabot.
Yup, manual ang adjustment talaga. Yung computer is only for checking.
Papaanong gusto sa harap lang?
I would like to retract my answer from previous post, iba pala ang manual alignment. Mas effective, or na tyempuhan ko lang yung computerized alignment nung isang shop hindi na calibrated angmga aparato? I had it aligned manually sa Wheelers, it costs 300 only. Nawala yung kabig ng manibela. Compared to a computerized check that costs 450, pero kahit na sabi sa computer display 1:1 left and right may kabig pa rin. Caster was also checked 1.0 = 1.0
ser san yang wheelers?
Sa Laon-laan going towards Banawe direction. You should be able to see it on your left after Sta. Teresita Hospital and another street. Katabi nya yung townhouses dun.
I think the shop is named Wheelers Suspension Haus.
uy tamang tama malapit samin heheOriginally posted by Ungas
lampas po ba ng banawe ito? saang street crossing sya malapit?
Bago mag Banawe makikita mo na sya. Maganda pumunta ng hapon on a weekday, walang pila. Kaninang tanghali napadaan ako dun, bukod sa tatlong sasakyan na ginagawa, may naka-abang pa na tatlo sa gilid.
Yung ibang sira ay hindi makukuha ng computerize alignment. My XTO after adjusting yung torsion bar ay na align lang ng tama using manual adjustment. Trial and error ang ginawa para mawala yung kabig. Yung laser alignment already showed ok, but still meron kabig (2 adjustment ng Isuzu Mnl, 2 laser adjustment ng Roadstar at 4 manual adjustment ng Roadstar bago nakuha yung alignment). Alam nung mekaniko kung ano ang iaadjust manually kaya ok nga. Ngayon takot na akong magpa adjust ng torsion bar.
san yan roadstar na yan sino nag service sayo.........after kasi nag pa adjust torsion bar sa cvite isuzu napapansin ko nauupod sa gulong ko yun labas naiiwan yun loob.....thanks
S.E.R.V.I.T.E.K. Pay the price, get good service and a good aftersales warranty to boot.
