Results 41 to 50 of 51
December 25th, 2003 03:25 AM #41
sirs.. pwede po patingin ng ilustrations or pic on whats in it...? tnx po... alvincochua*hotmail.com tnx
- Dec 2003
- 102
December 27th, 2003 10:26 AM #42This is getting interesting. Pahingi din ng email about the thing. Gusto ko kasing tanggalin yung CAT ko dahil restrictive. Parang bali wala yung headers ko. carloi*tri-isys.com. Zero emmission na kaya ako and at 150% power and fuel efficiency if I remove my CAT, install EGO AND Aerogas? Will it be worth my P10,000 investment?
- Sep 2003
- 75
December 30th, 2003 05:02 PM #43Originally posted by AC
Rene:nerd:
- Sep 2003
- 75
December 30th, 2003 05:12 PM #44Originally posted by carloi
- Dec 2003
- 102
December 30th, 2003 06:39 PM #45Thanks for the email. To create the venturi effect that you've been mentioning, your device will have to restrict the airflow of the exhaust system (ie from 2" to 1.5"). This will increase the velocity of the gas and will create a low pressure area which I assume is where the outside air is being drawn in.
This will not increase the velocity of the gas before the venturi throat which will not contribute to the efficient scavenging of the cylinders.
Think of a water hose. As you squeeze the tip of the hose, the water shoots out faster and farther. This does not mean though that more water is coming out of the hose.
Another thing, I use Mobil1 in my engine. I don't like putting any additives in there that may break down the delicate balance of my oil.
Punta na lang ako sa World Trade on the second week of Jan. Do you have an exact date already?Last edited by carloi; December 30th, 2003 at 06:42 PM.
- Sep 2003
- 75
December 30th, 2003 07:09 PM #46Carloi,
The World Trade Exhibit is tentative only, if might not push through. If you want actual DEMO/Testing on your vehicle, contact me ASAP at (02)874-0183 (Res.) // (02)757-6031 (Off.)//
(0926)3031871, we could go to Mr. Alegre's Office (Proj. 3, Quezon City). Also, watch in "Magandang Umaga Bayan" this week for a segment on EGO.
December 31st, 2003 03:10 PM #47
carloi,
just a side note... i won't recommend removing your catalytic converter if you care about the air and those who inhale it.
January 2nd, 2004 09:31 PM #48
interesting topic.... I wonder if the DENR/DOST will install this in their fleet?
- Sep 2003
- 75
January 15th, 2004 07:33 PM #49Originally posted by mbt
carloi,
I thought that CAT meant CATALYTIC COMBUSTOR (from Aero-Gas). ;)
January 20th, 2004 02:55 PM #50
is this a tailpipe end thinge? i had one removed when tested on our emission testing center, dahil istorbo sa pagpasok ng probe, wala naman nagbago sa takbo/andar ng makina nung natangal
doubledouble.
2024 Manila International Auto Show APRIL 4-7,...
