Results 1 to 7 of 7
    Sir,
    tanong k lang..
    1.) bkit may tunog ang civic ko matic sa 1000-15000 Rpm
    parang tunog ng hingal.
    beyond those range ok na sya.
    2.) yung pintuan sa likod since d masyado ginagamit, pag binubuksan.. TAK TAK ang tunog matigas. anu ba problem dun
    Jun 2006
    Quote Originally Posted by fedski View Post
    Sir,
    tanong k lang..
    15000rpm? baka sumabog na ang makina mo! Joke lang. I guess 1500 rpm to diba? When did you hast have a change oil and tune up, ok pa ba air filter and fuel filter mo?
    Try wd40 or white grease sa hinges ng pinto.
    baka kailangan mo na palitan automatic transmission fluid mo bos
    tama si bro userfriendly, lubrication lang ng hinges katapat niyan. wd40 or silicone spray lang sagot dyan
    done that...
    engine - change oil at tune-up.. recently lng wala pang 2 months
    pero matagal na itong problem.
    sa pinto, tried using WB40, no avail.. matigas talga ang pinto , alam ko sakit tlaga ng civic eto eh.
    yes. but have you changed your atf recently? i'm not an expert but this may be the culprit
    try mo silicone spray. i think its a better lubricant than wd40. kasi iyong akin smooth naman bukas sarado niya. and aside from the hinges, make sure you lubricate also the plastic-like-thing sliding in and out of your door. i hope this helps bro
    i would also recommend changing atf.
    Nov 2003
    sa rear just get a new hinge from honda. kahit anong greasing nyan di na mawawala if it starts getting noisy.
Civic Matic 96 problems
