Results 1 to 15 of 15
    diy kasi ako magpipintura alin kaya mas ok? alam ko na mas makintab ang urethane kaya lang is it worth it? doble kasi ang presyo nya sa acrylic.
    pros and cons naman po.
    kung DIY ang gagawin mo mas mabuti na kung acrylic, maraming orasyon ang pag pintura ng polyurethane... pero kung sa patibayan ng pintura nasa polyurethane.
    imho 2k na...sulit sa kintab at tibay...
    Jul 2003
    hindi ba mahirap timplahin yung 2k paint? pwede bang substitute having a good quality yung applyan ng magandang sealer before applying the color.
    sabi sakin dati ng pintor mas mahirap daw magpintura ng urethane lalo na kung ndi ka experienced... but super tibay nga urethane
    urethane is not really more difficult to apply - it's just more steps since it's basecoat/clearcoat. basecoat needs only to cover and be the right color, while clearcoat adds the shine and protection, and needs to be nice, wet and even (but not too wet or it will run).
    you can also buff out urethane much more easily if you have imperfections, or later on when the paint job needs sprucing up.
    urethane is also much more durable and less prone to cracking than acrylic
    2K na! tama si M54
    try mo muna isang panel.
    can i apply acrylic tapos mag clearcoat ako ng anzahl? may naririnig akong gumagawa nito. oks lang ba?
    pwede yan kaso the next time na mag reretoke ka anzhal na ang gagamitin mo.
    swabe ba kintab? gnun na lang cguro gagawin ko. saka ko na lang po problemahin pag retoke ulit.
    tatanong ko ulit kay ser kimpoy.
    salamat po!
    bossing bat di mo try Acrylic type clear coat ng dupont 380S
    makintab din ito o di kaya yung RM clear coat
    personally seen the 380s clearcoat applied next to a anz clearcoat, hindi sila nalalayo,
    try k92 paint its been in the market for a few months na din
    try mo rin yun dupont na hindi na ginagamitan ng topcoat clear, makintab na rin... kung magcocombo ka mas maganda at practical kung straight urethane na, kahit ibaiba ang brand, konti lang naman ang diperensya sa presyo ng basecoat, nakakatalo lang sa clear, yung combo na gimamit ko sa pickup ko ay tafeta white na anzahl, blue pearl na dupont, tapos topcoat clear ng ppg.... mahal pag straight na dupont o ppg...
    rod,
    mamumulubi ata ako sa dupont balita ko nga sa dupont pag spray mo pa lang makitab na agad.
    kimpoy,
    ser RM at anzahl lang ata tinda samin. pag rm na acrylic clearcoat ginamit ko halos pareho din ba sa anzahl resulta?
    paki detalye naman po sa pag apply.
    1. pag apply ko ba ng color paint anong grit ng liha gagamitin ko?
    2. tapos clean with thinner yung surface then apply yung clearcoat.
    3. tapos sand with superfine 1000 grit ba yun? yung 3m
    4. then rubbing compund. (anong brand ?)
    5. apply glaze (anong brand?)
    tama po ba yung steps ko?
    salamat po ng marami.
    fierari use degreaser when cleaning surfaces before painting it removes paint contaminants
acrylic or urethane?
