Results 11 to 14 of 14
April 10th, 2006 12:38 PM #11
self tuning na makina??? meron ba nun???
mababa masyado ang 400 rpm even for new model engines. dalhin mo na lang sa suki mong shop.
- Dec 2005
- 71
April 10th, 2006 10:24 PM #12mga sir,
---yong kasi yong sabi sakin ng isang mekaniko na self tune up daw....naluko ata ko ahhhh
wala ba vibrations? usually kapag ganyan kababa nanginginig na...tipid sa gas pero may trade off...
---- di ko naman maramdaman na nag ba-vibrate... basta pag takbo eh medyo mabagal lang yong response....
normal yung pag angat ng rpm sa ganong level pag cold start. it's a self choke feature of engines to bring up temp to normal levels. pero pag ganon kababa yung bagsak after warming up, di normal yun. try to have it tuned up. when was the last time you had your PMS?
--- last week lang po yong pms ko.. change oil and oil filter, cleaning of air filter and fuel filter, replace sparkplugs, timing, balancing and alignment/camber. may nakaligtaan pa po ba ako??? siya nga pala kanina bumili ako ng carb cleaner... OT: pano ba procedure non pag apply?? habang umaandar ba eh saka mo spray yong carb cleaner???
Nagkaroon ng ganayang experience yung Nissan Sentra ng kaibigan ko, series 3.... Cervo ang problema... sana hindi ganyan ang case mo. Di yan normal.
--- ano po ba yong CERVO?? mahal po ba yong pag nagpapalit??
medyo mahaba haba na po.... ask ko po uli kasi pagkatapos kong mag apply ng carb cleaner kanina yong idle ko umabot ng 1500rpm niya then ayaw ng bumaba. try ko adjust yong idle hanggang 1100 nalang at nakafull na ayaw na umikot yong pinag aadjust-san. kaso ganon parin may time na bumabagsak sa 400-500 yong rpm ko at parang mamatay yong makina ko...
April 11th, 2006 09:04 AM #13
400 rpm. baka 800 yan, increment of 200 per line sa meter. if your engine doesn't vibrate as in pati loob nag vibrate ok lang yan
Cabin Air Filtre Carbon activated, interchangeable with 27277-4JA0A/B P190 only. Almost P3k ito...
Nissan Navara NP300
