Page 1 of 2 12 LastLast
Results 1 to 20 of 34
    Jan 2004
    Okey b ang 4-tip spark plugs versus single tip? anong difference?
    Oct 2004
    i find it (4-tip) better. accelerates faster.
    In normal (stock) engines, it has no difference.
    Aug 2004
    Depends really on who you ask... some people swear by it, some people say it's trash.
    AFAIK, mas maganda ang initial running, but in the long run, regular tips may be better... basta platinum or iridium, though, mas maganda nga.
    I still prefer torquemaster sparkplugs.
    Nov 2003
    kahit 4 tip yan... the spark still only goes to one tip... it just has a choice of which one has the least resistance.
    i would still just choose a properly gapped, correct heat range regular plug over one of these fancy ones
    Quote Originally Posted by speedyfix
    exactly.ang daming naghahanap samin ng 4 tip ek ek na yan.di naman nila naiintindihan ang hinahanap nila...
    Nov 2003
    hehe! kaya it's our job to explain
    migs, yung isang kaibigan ko nakabili ng bosch super 4. he's askin me if pwde ba yung kanya, ksi sa supermarket lang yata nabili. ano spec or part number ang pwde sa kanya? his car is 2002 civic vti (vtec3). thanks
    Aug 2004
    if stock yung car then go for stock plugs pa rin po.
    Nov 2003
    i'm not sure what the part number is of the bosch super 4 para sa civic nya... he can remove the plugs from his car and if the new plugs are the same length and width then kabit na nya. kung mas mataba sya or longer di pwede.
    Dec 2003
    i didnt feel anything different when i installed denso iridium plugs..maybe psychological lng and for bragging rights (babaw) hehe
    Aug 2004
    Kung stock kotse mo, go stock plugs... para wlang problema
    Nov 2003
    wala naman talaga diff with irridiums. they're just better for sportier driving than regular plugs. pero depende pa sa heat range yun
    Mar 2004
    I still prefer splitfire spark plugs. mas maganda performance and mas sulit cya kasi matagal ang buhay nya. more that a year tumatagal sa akin yung isang set compared to the ordinary NGK plugs na 3 months lang ang buhay. yung torque master maganda ba talaga? 2600 yata yung isang set nun eh. glenn malapit sa inyo yung nagbebenta nung torquemaster diba? along kamias din
    BTW i'm using a 1600 saturn engine.
    Jun 2003
    nakagamit na ba kayo ng regular plugs pero may butas yung tip? any feedbacks
    Oct 2004
    mas malakas ang hatak nung 4-tip kaysa dun sa 1-tip.
    Jan 2004
    opinion lang po. ako haven't tried pa yung mga 4 tips na spark plugs. pero me thinks na mas ok ito kesa sa conventional na spark plug. however, i think ok ito assuming na wala kang problema sa ignition system mo or sa daloy ng kuryente. i'll have to try pa muna. kung ang price difference nila e konti lang ok yun. pag medyo malayo, wag na lang. iridium na lang.
    Oct 2004
    have also tried yung platinum tip, okay din. pero mas okay sa akin yung 4-tip. ride is 323familia
    Mar 2003
    Quote Originally Posted by Kicker15
    3 months lang tumatagal sa yo spark plugs??? bakit naman?
4-tip vs 1-tip spark plugs
