Sir,
tanong k lang..
1.) bkit may tunog ang civic ko matic sa 1000-15000 Rpm
parang tunog ng hingal.
beyond those range ok na sya.
2.) yung pintuan sa likod since d masyado ginagamit, pag binubuksan.. TAK TAK ang tunog matigas. anu ba problem dun
Sir,
tanong k lang..
baka kailangan mo na palitan automatic transmission fluid mo bos
tama si bro userfriendly, lubrication lang ng hinges katapat niyan. wd40 or silicone spray lang sagot dyan
done that...
engine - change oil at tune-up.. recently lng wala pang 2 months
pero matagal na itong problem.
sa pinto, tried using WB40, no avail.. matigas talga ang pinto , alam ko sakit tlaga ng civic eto eh.
^yes. but have you changed your atf recently? i'm not an expert but this may be the culpritengine - change oil at tune-up.. recently lng wala pang 2 months
try mo silicone spray. i think its a better lubricant than wd40. kasi iyong akin smooth naman bukas sarado niya. and aside from the hinges, make sure you lubricate also the plastic-like-thing sliding in and out of your door. i hope this helps brosa pinto, tried using WB40, no avail.. matigas talga ang pinto , alam ko sakit tlaga ng civic eto eh.
sa rear just get a new hinge from honda. kahit anong greasing nyan di na mawawala if it starts getting noisy.
