Results 31 to 40 of 62
February 19th, 2003 08:58 PM #31
Dun nagkaka-diprensya sa threads ng water drain plug, kung hindi naman forced fit ok lang. Kaso baka napwersa unang ikot ng plug, kahit ilang ikot na mali ang pihit paniguradong magkakasingaw na yun. Pero pwede gawan muna ng paraan, have you tried using teflon tapes first? MAs mura ito kesa singilin ka ng bagong filters.
February 20th, 2003 09:12 PM #32
guess what happened this morning. 2 days kong hindi pinaandar yung patrol, natakot ako baka lalong lumala yung sira, pero natakot din ako sa sinabi ni ARB. so i tried to start the engine, pero before starting, i pumped the fuel filter muna. then pag start ko, walang pugak. :| ano kaya nangyari? bukas try ko start na hindi ko i-pump yung filter.
Signature
February 21st, 2003 02:58 PM #33
this morning, hindi ko pinump yung fuel filter, hirap mag-start. so pinump ko nalang. ok na. ano kayang problema? hindi ko pa madala sa casa, manganganak na kasi si mrs any day now. and 1 hr drive (45 kms) yung nearest nissan casa.
Signature
February 21st, 2003 03:11 PM #34
Natutuyuan ka ng diesel sa fuel line mo, malamang sa may singaw nga yung fuel filters na kinabit mo. Have you tired to remedy it with teflon tapes? Para incase of emergency na gamitin mo yung sasakyan eh umandar ng tama.
Like what you said, binomba mo yung fuel pump, naturally may diesel sa fuel line. Leave it overnight papalit yung hangin sa fuel.
February 21st, 2003 06:16 PM #36
Subukan mo muna lagyan yung ilalim sa water-fuel indicator & drain plug. Dito madalas nasisira ang thread.
February 21st, 2003 07:46 PM #37
i think may check valve some where na stuck open, what happens is that the fuel goes back to the tank, usually in the pump there is a check valve inside so that the fuel will remain in the lines, thats why when you pump it it will start right away because the fuel will go up the lines. try to let your car idle for 15 mins and see if "papalya or the engine will stop running", as in pag start do not touch the accelerator pedal and observe.
February 21st, 2003 09:17 PM #38Originally Posted by ARBSignature
February 21st, 2003 10:49 PM #39
you used replacement filters? try to tighten it or check maybe the o-rings are not that sealed so there is air coming in which makes your fuel drop back.
February 22nd, 2003 12:02 AM #40
i'll check everything tomorrow morning. tnx for all your replies. :wink:
Signature
Sensing a hint of weakening on our 6yr old Thai Pana DIN74, went to the distributor to have it...
