Results 21 to 30 of 62
- 10,620
February 18th, 2003 01:23 PM #21dalhin mo na sa casa habang under warranty,
mahirap na mag kalikut baka ma void warranty
February 18th, 2003 05:57 PM #22
palyado ba ung makina?
ganyan din ung samin nun.. --dalin mo na lang sa casa.
Tsikot Member Rank 3
- Dec 2002
- 636
February 18th, 2003 06:57 PM #23Boybi,
Does the new patrol use common rail injection? If so, it may require a thinner engine oil to pressurize the injection system- just like the 3.0TD trooper.
When you start it cold, the oil is too thick to immediately enter the high pressure rail but once warmed up, it thins out so you get constant fuel flow.
What oil do you use on the engine? What does the manual recommend?
Just thinking aloud.:wink:
February 18th, 2003 07:52 PM #24
kiper18,
anong ginawa sa patrol nyo? ok na ba now? and nakuha mo naba escape mo? what color?
jackaroo,
honestly, i don't know if it uses common rail injection, and what kind of oil is used. iniiwan ko lang kasi sa casa pag pms.Signature
February 18th, 2003 10:16 PM #25
boybi!!!!
feeling ko...sakit talaga ng patrol yan...
kasi ung safari naman...laging nagl-light ung orange thing na indicator sa fuel filter pag first start sa umaga...and the engine is parang "pupugak-pugak"...pero hindi naman namamatay....
but pag mainit na...and when i stepped on the accelerator....nawawala ung light sa indicator...and nagiging mas smooth ung idling....
nga pala...everytime na magpapalit ako ng fuel filter...daming tubig....and bi-ni-bleed nga pala un....
February 18th, 2003 10:58 PM #26
boybi: What you're experiencing might be the injector defect of the ZD30. As far as I know, Nissan Bacolod has reported 16 Nissan Patrols with problems similar to yours. One more thing, the ZD30 is direct injection only.
February 19th, 2003 09:55 AM #27
based on your symptoms it seems that there is air in your fuel line, this one of the reasons why when you start it up it will die unless you step on the accelerator, check the check valves on the filters. it will dissappear when the engine is hot because the air is already gone in the lines. i guess it happens when you leave it overnight and will be worse if you leave two days or more. i also experienced this on my isuzu. IMO lang.
February 19th, 2003 08:43 PM #28
meron pa ako isang problem. yung fuel filter and water separator na pinalit ko ay replacements lang, not oem. pag dinala ko sa casa, hindi kaya ako pa ang masisi dahil replacements lang ang ipinalit ko?
Signature
February 19th, 2003 08:46 PM #29
Baka pang TD42 yung binigay na parts? 8O
Hindi naman siguro, pag nakita nilang hindi OEM yan, papalitan nila ng orig. They'll charge you for new ones. Tapos sasbihin na dapat orig kakabit mo sa susunod.
February 19th, 2003 08:52 PM #30
hindi ba pareho filters ng TD42 sa ZD30? pero bago ko pinakabit kinompare ko naman both filters and pareho naman mga butas.
Signature
Traffic!
