Results 301 to 310 of 325
September 9th, 2003 12:33 AM #301
hihintayin ko po ang inyong litrato. makakatulong ito sa aking susunod na hakbang sa pagnanasang umikot ang apat na gulong ng patrol.
Signature
September 9th, 2003 03:44 PM #302
Eto na po yung mga nakunan ko, ang hirap sumuot sa ilalim di ko makunan ng tamang angle yung transfer case links:
Note: Ginuhitan ko ng marker pen para may palatandaan, di sya gumalaw from 2H-4H, nung nilipat ko sa 4L bumaba ng bahagya.
On 2H , On 4H , On 4L , On 2H another angle , On 4H another angle , On 4L another angle , Transfer links 1 , Transfer links 2 , Transfer links 3
September 9th, 2003 04:51 PM #303
Kung hindi siya gumagalaw, ano ang nagagalaw when you shift the T/C?
September 9th, 2003 05:21 PM #304
Gumalaw ng kaunti yung tinuturong lever ni boybi when I shifted it into low gear. I think yung upper lever ang control para sa power to the front prop shaft.
September 9th, 2003 07:06 PM #305
naguluhan ako sa pics a. meron ka bang nakikitang similarity sa transfer case natin? saan ba dyan ang shifter mismo?
Signature
September 9th, 2003 07:17 PM #306
Arrow points to the shifter's base. If you could see the fine brushes along with the lever rod, that goes inside the cabin.
September 9th, 2003 07:37 PM #307
pls check kung tama pagka label ko sa mga links.
one end of link 2 is connected to link 1, but where is the other end of link 2 connected?
how does link 3 move? both its ends are bolted to non-moving parts. does one of its ends connect to the lever you mentioned as "lever sa taas"?Signature
September 9th, 2003 08:03 PM #308Originally posted by boybi
how does link 3 move? both its ends are bolted to non-moving parts. does one of its ends connect to the lever you mentioned as "lever sa taas"?Last edited by Ungas; September 9th, 2003 at 08:08 PM.
September 9th, 2003 08:12 PM #309
GQ & GU Patrol Transfer Case side-by-side:
di ko makita yung other lever.
and bakit 2 yung meron electric wire? one on the side, the other at the top of the transfer case.Signature
September 9th, 2003 08:20 PM #310
Hindi nga yata pareho ang transfer case. Baesd from the other shot that I took. 2 wires din yung sa akin, isa sa taas isa sa gilid.
Para di na sumakit ulo mo, takbo ka na sa Nissan then pakabit ka ng orig parts that really fits your model.
I don't have proof but it seems like the CRV shrank from the previous generation.
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
