Results 251 to 260 of 325
September 7th, 2003 12:06 AM #251
Huwag mo na problemahin iyan. Basta palagyan mo ng 4WD system. It will work naman in the same way as most other 4WD systems.
Saka mo na lang pag-aralan.
September 7th, 2003 12:08 AM #252
gagawin ko muna kasi yung test ni ARB. tignan ko kung meron iilaw sa dashboard. kaya kelangan kong malaman kung pano i-shift.
Signature
September 7th, 2003 12:12 AM #253
To be safe, apply some downward pressure.
September 7th, 2003 12:14 AM #254
try ko i-test bukas. sana meron umilaw. para drive shaft and shifter nalang kelangan ko
Signature
September 7th, 2003 12:18 AM #255
Sana kunan mo din ng pic.
Para makita ko kung ano hitsura nung lever underneath.
September 7th, 2003 12:20 AM #256
nabuksan ko na yan dati. ang nakita ko lang e yung rubber boot ng shifter. hindi ko na kinalikot. bukas kalikutin ko.
Signature
September 7th, 2003 12:43 AM #257
ano pala tawag dun sa pagkakabitan nung drive shaft sa likod? sa harap ito yung flange from the front diff. e yung sa kabilang dulo nung shaft?
Signature
September 7th, 2003 12:45 AM #258
flange din yun. From the transfer case nga lang.
September 7th, 2003 06:06 PM #259Originally posted by ARB
first, check your front diffs, may flange dyan for the driveshaft. jack up the front of the vehicle and rotate the tires, if the flange moves then the diffs are functioning, or it has internals.
second, uncover te shifter cover, if there is a way that you can shift the 4wd mech try to shift it, so that you may find out if an indictor will light up in the dash.
yung nakabilog, yun kaya yung pang shift ng 4wd?Signature
September 7th, 2003 06:20 PM #260
Bakit nasa ilalim? Ibig sabihin dadaan pa ng linkage?
Wala bang nasa taas ng housing banda?
yup... DNGA-B = Avanza, Veloz, (new) Vios and Yaris Cross TNGA-C = Corolla E210, Corolla Cross,...
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
