Results 231 to 240 of 325
September 6th, 2003 11:08 PM #231
since parehong open diffs ang front and rear ko, and wala pa akong diff lock, safe bang ipang offroad ito?
Signature
September 6th, 2003 11:10 PM #232Originally posted by OTEP
...ang tindi mag-research ni Ungas.
boybi::: That is why I always advise not to use 4WD on pavedroads even on flooded areas. Just drive in the opposite direction when you feel diff bind, and slowly straighten your steering.
Pinahirapan ko pa sarili ko, eto pala ang kumpletong explanation. How four wheel drive works
September 6th, 2003 11:11 PM #233
boybi,
Open/open din ang diffs ko. Pero masaya naman ako diba?
Actually mas safe nga yan kasi hindi masyado stressed ang drivetrain. You may get stuck, but at least less ang risk mo of breaking halfshafts, burning clutches, etc.
September 6th, 2003 11:15 PM #235
May center diff lang ako to enable me to run 4H on-road. It does not help any in off-roading kasi ang locked center diff works in the same way as the direct drive transfer case of your Patrol or most other 4x4's today.
September 6th, 2003 11:16 PM #236
sa mga offroading nyo, hindi ba kayo nagtturn kapag naka 4wd?
Signature
September 6th, 2003 11:19 PM #237
The low traction surface compensates kaya walang binding during off-roading. There is enough tire-slip so walang binding na magaganap.
September 6th, 2003 11:20 PM #238Originally posted by boybi
September 6th, 2003 11:24 PM #239
Binding is a phenomenon on high traction surfaces only. Wala niyan on loose rocks, mud, lahar, sand etc.
September 6th, 2003 11:32 PM #240Originally posted by Ungas
What do you mean "nagtturn"?
look at the pic of OTEP's pajero here. (pahiram ng pic, Ungas)
http://image.pbase.com/u25/ungas2/la...0.DSCF0008.jpg
di ba he's turning to the left, hindi ba magkaka binding dito?Signature
I don't have proof but it seems like the CRV shrank from the previous generation.
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
