Results 221 to 230 of 325
September 6th, 2003 08:18 PM #221
as long as you dont use 4wd, even if you dont have hubs there will be no binding on high traction surfaces. open diffs naman siguro ang stock ng patrol.
shifter and driveshaft na lang ang bilhin mo.
September 6th, 2003 08:20 PM #222
Yup open diffs ang Patrol sa harap.
September 6th, 2003 08:51 PM #223
meron ba kayong alam na site about 4wd systems, yung me mga illustrations sana about diffs, locks, hubs, binding, etc.?
Signature
September 6th, 2003 10:47 PM #225Originally posted by OTEP
Yup open diffs ang Patrol sa harap.Signature
September 6th, 2003 10:52 PM #227
September 6th, 2003 10:52 PM #228
Yung sa local market open diff. Kasi kung LSD may warning yan sa door jamb or sunvisor. And wala naman siyang difflock switch. So open siya. Hehehe.
Shet, ang tindi mag-research ni Ungas.
September 6th, 2003 10:59 PM #229
from 4x4abc.com:
The slowing effect caused by front wheels stresses all components between wheels and the transmission. It causes mechanical components to bind instead of moving freely - this situation is called "axle binding" ,"driveline binding" or "driveline wind up". First indicators while driving is a hard steering feel and the vehicle displaying jerky movement. Shifting back to 2WD will become impossible (gears and levers are extremely forced together). Continued 4WD use on dry surfaces will cause the weakest links to break (U-Joints, axles, differential gears, transfer case gears, drive shafts).Signature
September 6th, 2003 11:02 PM #230
Drive in reverse then slowly straighten out steering wheel. Madalas ako nagaganyan nung nag-aaral pa ko gumamit ng 4wd. hehehe.
Toyota's Land Cruiser 3�� Finally Gets a Hybrid Version with the 2�26 Model — The Most Powerful Yet...
2021 Toyota Land Cruiser LC300
