Results 191 to 200 of 325
September 6th, 2003 10:01 AM #191
Aanhin mo ang front hubs kung wala kang axles and oil seals sa loob? Kung kakahuyin mo naman baka kasi maymagkamali pa ng paglipat, 2 pa sasakyan nyo hindi tatakbo o may masira.
Teka, baka nga di rin pala pwede ang axle swap kung hindi pareho ng final gears ng GU vs. GQ.
- 10,620
September 6th, 2003 10:22 AM #192hmmm gandang project iyan.
check first if you have the same gearing.
pa swap mo na front caboodle first
September 6th, 2003 11:51 AM #193
Mas madali siguro kung kunin mo ang buong axle ng donor unit. Para hindi ka na maglipat ng internals. Bale yung ring and pinion gears mo na lang ang ililipat into the axle to be put in. Pero not every shop can swap r&p's. Hindi ba may ginagawa pang parang 'lashing' sa mga ganitong gears? Hindi ko lang sure ha.
Get the rear difflock na din.
September 6th, 2003 12:33 PM #194
dami palang problem. akala ko pwde ng isaksak lang yung front hubs and the propeller shaft, ayos na. napapaisip ako a.
Signature
September 6th, 2003 12:35 PM #195Originally posted by ARB
boybi- hindi pa confirmed if they can deliver it direct there. hanap ako muna ng ibang forwarder.Signature
September 6th, 2003 12:36 PM #196
Wala daw kasing laman yung 'bungo' sa harap. Yun lang naman ang basic problem. If you can find a shop that will trasfer the internals from one housing to the other, it would not be that hard.
Mura lang naman mga oil seals niyan. I think yung lang ang itatapon niyong parts in the process bukod sa needing new gear oil to fill the diff up.
Kahit sa future mo na kunin ang difflock.
September 6th, 2003 12:52 PM #198
Nasa loob nun ang differential mismo. Yung mga ring and pinion. Saka yung halfshafts papunta sa bawat gulong.
Dun din nilalagay ang diff locks or LSD.
September 6th, 2003 12:56 PM #200
Baka meron since buong sasakyan naman ang kinakatay dun diba?
Sa local market ng automobiles, mostly uso yung paying more for less. Yung stripped ang maraming...
China cars
