Page 15 of 33 FirstFirst ... 511121314151617181925 ... LastLast
Results 141 to 150 of 325
    #141
    Kung meron ba akong mailalabas para sa iyo bakit hinde, kaso cash strapped din ako.
    #142
    isanla muna natin yung front and rear bumpers mo. pati yung lightforce. :D:D:D
    Signature
    #143
    Wow! Those figures are plain ASTRONOMICAL! Pautangin niyo rin ako mga bossing! hehehe :D
    #144
    Originally posted by Ungas
    Halos umabot na ng kalahati ng 200K. Pwede na yan!
    Estimated guess ko:
    Bushings: 15,000.00
    Multimeter: 8,000.00
    4WD Shifter: 10,000.00
    Propeller Shaft: 20,000.00
    Locking Hubs: 10,000.00 (5K each)
    Labor: 39,000.00
    may front axle na ba yung 4x2 na GU? yun kasi ang isang problema ko sa pag convert ng GU ng father in law ng kapatid ko, kung sakaling meron na konti na lang problema ko
    #145
    May front axle na siya including the diff and internals (unlike the Pajero na walang front diff). Walang pagkakabitan ang gulong kung wala yung axle. :D
    Sep 2002
    #146
    ungas, otep: thanks for clearing that up, didn't have any online source of information regarding philippine models so i had to look up nissan australia and maybe i didnt understand it clearly. they did have manual or auto locking hubs on different patrol models. mahirap talaga kapag baguhan =)
    kimpoy: how come nasira yung hub mo? what are the differences among the 3 types?
    pajero: as for the 10 seater exemption; i really don't get that. a suburban would probably never be used as mass public transport, and yet it gets exemption?
    how "good" would the oe upgrades be compared to aftermarket ones? i changed my suspension to omes because the original shocks weren't performing as well as i'd like.
    boybi: fyi. i have a friend who replaced his front bumper with arbs and he changed his suspension as well to the stiffer omes.
    #147
    Meron na po kaso wala nga lang front locking hubs. Coil over axle ang setup ng Patrols from 1993 upto present models. Leaf over axle naman sa MQ series (box type).
    Basically same parts lahat ng underchassis ng Patrols, konti lang ang binabago nila.
    #148
    I think nasira ang hub ni kimpOy because he was rocking the vehicle back and forth para ma-overcome ang obstacle. May tendency kasi ang auto hub na mag-partial disengage when backing up (even in 4H or 4L). Kaya pag-abante niya ulit, ayun durog ang internals. With a hybrid hub (Patrol OEM) you won't have this problem because you can keep it in LOCK mode via your tire wrench.
    Full manual hubs give you the most control. You can drive it in 4L without activating the front axle (just set hubs to FREE). Useful if you need the engine braking or torque multiplication of 4L but you don't need the additional traction of 4WD.
    #149
    naka bilstein shocks na ako on all 4. TJM springs sa likod. oem parin springs sa harap.
    Signature
    Sep 2002
    #150
    otep: how is that tire wrench thing done? does one have to get off the vehicle? sorry, still have lots to learn about 4wd. correct me if im mistaken, manual, you engage/disengage the hubs manually; auto, some mechanism does it for you depending on the gearing; hybrid =auto with manual option.
    thanks.
TJM/ARB bumpers & 4wd Conversion of GU Patrol
