Results 1 to 4 of 4
- Feb 2010
- 1
January 2nd, 2013 08:15 PM #1Hi Guys,
I would just like to ask how much kaya ang shocks mount coz i have my car checked (Nissan Exalta STA), as per dun sa mekaniko shocks mount daw cause nun kumakalampag sa both front sides ng car ko.. My shocks were new, after makabit yun shocks napansin ko na may sound na bigla, una sa left then now both sides na.. P6500 daw lahat if ill have it fix ksama ang alignment ng tires ko.
Pa help naman po as to where can I bring my car na mura and maayos gumawa..
Thanks so much in advance
January 3rd, 2013 09:37 AM #2
Try to canvass first the prices of the shock mounts. I'd still recommend OEM, a good surplus mount if you can find one, before going for replacements.
Shops I check with usually would be Nisway (Ligaya, near Marcos highway, 647-3746) or Yen Commercial in Banawe. In Pasay, there's Advance along Taft Ave. Get a second opinion just as well before having the part replaced. When i had kalampag on my 2001 B14 Sentra before, we had to do a trial and error on some parts before finding the culprit (as it was an intermittent sound).
January 3rd, 2013 11:49 AM #3
maraming sources ang kalampag and tama na magpasecond opinion ka nadin.
but if, ikaw for yourself check its condition, sa top part palang if marami ng cracks and yung rubber is muka ng "tuyo",
might as well replace that also, with your new shocks, the shock mounts will be reinforcing a lot more force.
Im using RBI shock mounts replacement, so far so good,
but if you have the resources, do get OEM, way more better.
- Dec 2008
- 4
September 13th, 2013 05:46 PM #4mga sir idea naman po how much ang shocks front and rear para sa Nissan Sentra S4... TIA!
Suzuki JIMNY [merged threads]
