Results 31 to 36 of 36
- Feb 2012
- 70
May 30th, 2012 05:40 PM #32
pag loose compression, the minimum thing that can be done is top overhaul, imho.
for additional information on loose compression, please see this link:
What causes an engine to loose compression
What Causes Engine Compression Loss? | eHow.com
- 52,694
May 31st, 2012 04:20 PM #33i would ask that to my mechanic. if top overhaul only (valves, valve guides, valve seats), in many models, it can be done with the engine block in place. if the piston rings, connecting rods and crankshaft are in need of service, it may be easier to do with the engine out of the bay. if machining of the engine block is needed, definitely the block must be brought out.
May 31st, 2012 07:07 PM #34
have your battery check then kung ok pa sunod un mga belt kung worn na then altenator kung tama un charging nya
- Feb 2012
- 70
- Feb 2012
- 70
June 2nd, 2012 06:50 PM #36update guys. . ok na po yung series 3 ko. . pinalitan lang po yung ignition switch. . halos sunog na yung ignition switch ko, . ayun po, . nagpalit ako ng bgo, as in brand new. . nabili ko po ng 2,500 . . aray pa din. . kakapirasong piyesa ang mhal. . rare kasi, . last stock na nga yung nakuha ko eh. . so ok na po yung kotse, . 1 click start na po, . ng nagpa gas po aq sa petron, . confident na po ako patayin yung makina hehe. . kasi alam ko 1 click start lang yung kotse. . thanks sa mga help nyo guys. . kayo na talaga . . so far i spend 25k na. . para ma kondisyon yung kotse ko. . at least ngyn, worry free na tlg . . kayo na guys kayo na . . . thanks mga bro. ;)
ganda sana, if we can exchange discharged batteries for fully charged ones, the same way we...
All New Toyota Corolla Cross
