Results 1 to 5 of 5
- Feb 2008
- 9
July 17th, 2008 06:49 AM #1Guys, need your inputs. Ung atima ko kc, parang nabubulunan pag umaandar specially pag medyo mainit na makina. Hindi naman nag ooverheat pero mapapansin mo ung rpm akyat-baba. Me time pa minsan na sobrang baba na hanggang mamatay makina. Pag off ung aircon, rpm reads 800 pero pag on ung ac, rpm reads 1100. Napapansin ko pag tumatakbo ng medyo mabilis or pag nag rerevolution (above 1500rpm), ok naman sya at nawawala problem.
Dinala ko sa isang mechanic ang sabi nya, kuryente daw problema. kelangan daw tune up ung computer box. dinala ko rin sa other mechanic at ang sabi naman, airflow sensor daw papalitan.
Has anybody here experienced the same problem? Wat to do?
Any inputs will be appreciated.
Thanks in advance
- Feb 2008
- 9
July 17th, 2008 08:48 AM #3
Oh boy...that could be a LOT of things,,1st and cheapest is to look for vacuum leaks and change the air and fuel filter.
Im also guessing that your check engine lights is also on.
Dirty or bad Idle Air Control Valve (IACV) is the problem here. Located on the back/front of the intake manifold and is screwed on with 2 12MM bolts. Take it off, clean it with carb cleaner, put it back on.
July 17th, 2008 11:22 AM #4
Most common issue with SR20s will be the throttle body, there's a hose or two near the TB that can get clogged and will affect the engine. Just send it to Nissan (i prefer Mantrade Pasong Tamo) for TB cleaning and you'll be fine, that'll include all the necessary computer checks as well.
Choosing one would depend on your driving and parking conditions. Do you have your own garage =...
MG4 EV Standard vs BYD Atto 3 Dynamic vs Toyota...
