Results 791 to 800 of 1303
November 19th, 2010 08:22 AM #791
I agree with you bro, shauskie. I like driving our Vanette in high speed curves. Very stable. Hangga ngayon, ginagawa ko pa rin iyan just to check how good the suspensions still are,- okay na okay pa rin...
Iyong dati naming Gen3 Starex,- walang panalo. Para kang tataob sa high speed curves dahil pronounced ang body roll...
11.3K:snow:
- Dec 2006
- 273
- Feb 2008
- 117
November 20th, 2010 08:45 AM #793bro i tried lowering my van, just removed the front rubber block and at the rear installed 2inch lowering block. AFter a month i returned the rubber block in front sobrang tagtag kasi, i know theres other way lowering it but ngyaon rear ko lang nakalowered..
anyway ganda pag nakalowered front gapang na gapang ang looks poging pogi
*ll
anong offset ng van mag wheels natin? Gusto ko sana medyo luwa eh
kaya lang nakakita ako ng 40+ offset papasok kaya?
share ko na din baka type niyo
http://www.sulit.com.ph/index.php/vi...rds=114+pcd+15
what do you think guys?
- Apr 2010
- 7
November 23rd, 2010 05:19 AM #794shauskie
nagpalit nako ng contact point... hindi kya clutch ang kylangn kong pagawa?
- Jan 2006
- 230
November 23rd, 2010 10:02 PM #795based lang sa problem description mo kasi the most probable cause will be ignition timing kasi di mo mapa rev ng higher ang engine. if clutch naman..probable effect will be higher rpm pero slow ang takbo or either mahirap ikambyo o madaling ikambyo kahit di mo apakan ang clutch pedal..
kung sa gas naman..pupugak sya pag medyo kinapos on attempt to go up higher rpm..
- Nov 2010
- 3
November 25th, 2010 01:08 PM #796
November 25th, 2010 01:30 PM #797
shaus! tulong....
Hindi ko pa nababaklas ang cooler box ko... although disabled na ito dahil tinanggal na namin ang cooling coil.....
11.4K:eathis:
- Jan 2006
- 230
November 25th, 2010 09:25 PM #798sure bro cvt...
*bokxz - welcome sa thread ng vanette bro..about sa cooler box..sa labas ng van ang access..sa ilalim ng flooring...natatakpan ng front ac condenser kya di mo kita..sipatin mo sa medyo gilid...4 nuts na 10mm lang yan. pero pag nakakabit pa yung conduit pipe for cooling coil ng cooler box di mo makakalas from van...kaylangan mo idischarge ang freon..hope this help..good luck pre..
- Jun 2010
- 354
November 26th, 2010 01:10 PM #799Musta na po to all ka vanette. busy parin ako sa baby namin kaya di makapat internet
- Jan 2006
- 230
November 27th, 2010 12:36 AM #800
Interesting thread—really important to consider the broader impact of the National ID Law beyond...
National ID Law
