Results 671 to 680 of 1303
- Feb 2008
- 117
- Jun 2010
- 354
- Jun 2010
- 354
September 21st, 2010 05:42 AM #674Guys ok lang ba na 1000rpm ang idle? tapos pag naka aircon umaabot siya ng 1200rpm? pag lower 900rpm naman nanginginig yung van ano po kaya solusyon dito?
- Jan 2006
- 230
September 21st, 2010 09:58 AM #675
- Jul 2007
- 4
September 21st, 2010 02:19 PM #676Good afternoon mga fellow vanette lovers.... Newbie here. I bought my van last May 22 and had the following repairs done:
Replaced the Power Steering Pump (sumusuka na kasi ng ATF tapos pagkainit-init nung reservoir)
Replaced the condenser fan (biglang di na gumana yung A/C. Di na makuha sa freon charging nung chineck, sira na yung fan as well as the relay)
Replaced the ignition coil twice (nung una, ayaw na syang magstart nung chineck ng mechanic, ayaw ng maglabas ng current yung ignition coil. Yung pangalawa, sumabog yung ipinalit na ignition coil)
Regular tune-up (changed oil and oil filter. BTW, I used Mobil Special 20W-40 and added STP Oil Treatment, changed air filter, changed HT cable and spark plugs)
Replaced Front Tires with new ones
Replaced Inner and Outer Tie-rods (ayaw i-align sa Servitek. Sira na raw yung mga tie-rods.
Other items for future replacement and checking:
Central Locking System (yung alarm okay pa pero ayaw ng gumana nung power locks)
Front Windshield Washer (ayaw bumuga ng tubig, may idea ba kayo kung saan ang pump nun?
Transmission and Gear oils (kasama dapat sa tune-up kaso ubos na ang budget
Seat covers (may napagtanungan ako dun sa Abad Santos sa Tondo, 4500 lang leather na. Kung sosy, meron dun sa Ortigas Center 8K)
Shifter Knob and Cigarette Lighter (gusto ko yung katulad nung sa car ni Frankie sa Death Race
Magwheels center caps (200 daw isa nun dun sa Nisparts sa Banawe)
Fuse Box Cover (Hirap manghula!!!!)
- May 2010
- 26
September 21st, 2010 05:00 PM #677guys kumakain ng langis vanette ko huhuhu, pero malakas pa naman sya, naka 125 pa rin ako sa nlex with 10 passengers, wento tagaytay pero di naman ako ibinibitin, meron kulay blue na smoke sa umaga and kelangan ko pa paintin para gumanda takbo. walang usok sa dip stick, pero nung buksan ko yung oil cap while tumatakbo engine lakas ng pressure as in hangin na lumabalas..... overhaul??? ouch
- Jun 2010
- 354
September 21st, 2010 05:58 PM #678
- Jun 2010
- 354
September 21st, 2010 06:17 PM #679
- Jan 2006
- 230
September 21st, 2010 09:41 PM #680kagagaling nyo lang ng bicol e..di ba..pero pwede rin...trail ride na tyo..hehe..
yung mga vacuum leaks anywhere on intake side mo mahahanap yun. try mo takpan bawat makita mong vacuum ports..or spray some lubricant anywhere sa gilid ng carb..pag nagbago idling kung san mo nabugahan..nandun yung leak..linisin mo rin agad yung ibinuga mong lubricant ng carb cleaner after macorrect mo yung leakage. gud luck men..
brake pad- malamang di na maganda ang lapat ng brake caliper mo sa harap. maluluwag na ang mga guide pin or nearly stuckup na pati yung piston kya medyo tabingi ang ipit ng brake pads sa rotor...yung squeak sa material ng pads yun..yung sakin nakalimutan ko na yung brand pero di rin masyadong makapit yung nabili ko.
Interesting threadreally important to consider the broader impact of the National ID Law beyond...
National ID Law
