Results 11 to 15 of 15
January 4th, 2013 12:24 PM #11
^The A/C has been cleaned already anytime recently? You can try starting there and also ask the shop what can be done to improve the cooling further. Over time pag madumi na yung evaporator and condenser, performance will deteriorate. Adding a better tint with good heat rejection can help.
January 4th, 2013 12:48 PM #12
ang a.c. ng urvan malamig naman wag lang over loaded....
seating capacity lang dapat... 12 including driver... kaso nga lang pag dating talaga sa likod hindi na inaabot ang mga naka sakay sa likod at sinolo na ng nasa 2nd and 3rd row ang a.c....
mag add nalang sila ng addl. evaporator fan sa gitna... ayan ang napansin ko na ginagawa ng lahat ng pumapasada medyo hindi nga lang maganda tingnan... pero ang imptortante hindi naman mainit....
January 5th, 2013 08:01 PM #13
Cleaning and pull down of AC evaporator for 2.5 years old Urvan is not advisable, because there is possible refrigerant gas leaking on fittings after a couple of period of re-installation of the system. The ideal is to frequently clean the front and rear AC fan blower to eliminate dust coming in into the evaporator fins.
January 6th, 2013 02:56 PM #14
Shouldn't the rubber o-rings be replaced as well during A/C cleaning? When you don't, on any car, chances are it will leak indeed (happened to me several times). I agree that keeping the "environment" of the A/C clean from dust does go a long way in preventing dirt build up; also choosing where you park as leaves are usually a culprit in contaminating the A/C system as well.
- - - Updated - - -
- Jul 2011
- 262
February 13th, 2013 07:39 AM #15advisable ba na magpainstall ng evaporator fan kung under warranty pa yung urvan? if ever anung evaporator fan ang sakto sa urvan? saan po makakabili nito? TIA
Daming issue ng SU7:grin:
Xiaomi E-Car
