Results 1 to 10 of 14
- Apr 2010
- 14
April 8th, 2010 07:39 PM #1good pm mga sir anu po kya fuel injected engine ang pwedeng ipalit sa engine ng 97 model sentra super touring ko ga16(1600cc)??carb type pa kasi ito..thanks po kng pde po paki include na din price range thanks po uli..
BANNER BANNER BANNER
- Jun 2008
- 1,439
- Sep 2007
- 46
April 8th, 2010 10:20 PM #4sir kung super touring yan hinde po yan carb type. madalas lang napapgkamalan carb type ang ga16dne kasi vertically mounted ang throttle body.
kung ang budget ninyo po ay 50k below i suggest SR20de. kung may itaas pa ng mga 70k-80k SR20ve
- Apr 2010
- 14
April 9th, 2010 12:06 PM #5nasa magkanu na po ba yung sr20de??yung sr20 de po ba ay pde lagyan ng turbo na bolt on lang or mas mura pa din yung sr20det kng magkakabit ng bolt on pa?
4mos ago nagpunta po ako ng imus may nakita ako engine dun nisaan neo anu pong engine yun??2.0 daw po yun..
April 9th, 2010 03:09 PM #6
baka neo vvl yun. sr20ve. hindi carb type ang super touring, sino ang nagsabi sayo na carb type ito? fuel injected yan ga16dne ang ngalan ng engine natin.
- Sep 2007
- 46
April 9th, 2010 04:55 PM #7
- Apr 2010
- 14
April 9th, 2010 11:52 PM #850k po yung sr20ve sa evangelista..yung sa imus nakalimutan ko na will try to go back there kasi if i remember it right may sr20de dun na 22k lang check ko uli..
*sir kurby san po kau sa lp??matigas po ba clutch nung auto nyo??yung sa amin kasi ang tigas ng clutch bagong palit naman ang pressure plate at clutch disk sabi bka daw sa cable nireplace ko na medyo matigas pa din e..
salamt po sa pagreply mga sir..pa tip na din po san kau nagpapagawa ng sentra nyo..stock lang po basta matino na stock ok na..pag may budget na stock sr20 de na lng.. :-)
April 10th, 2010 12:58 AM #9
The 97 Sentra ST is using a GA16DNE engine. It is an EFi engine. It is similar to the GA16DE engine found in the B13 Sentra and Sentra Exalta but it has a downdraft style intake manifold. The GA16DE has a sidedraft style intake manifold.
Performance difference is minimal.
GA16DE = 110 hp
GA16DNE = 105 hp
If you still want to upgrade your engine, your options would be going for the SR series engines. Most common is the SR20DE which is rated at 140 to 145 HP stock. You can tune this engine to produce 180hp N/A.
Other alternatives are SR20DET or the rare SR20VE, both producing over 200hp. There are also other types like the SR16VE and some SR18 series.
If you plan to upgrade the engine, be prepared to upgrade other areas of your car as well. These would include the brakes and suspension. The suspension would need more attention because the SR20 engine is heavier so you will need to have stiffer springs just not to bottom out the front end whenever you hit a bump on the road.
- Apr 2010
- 14
April 17th, 2010 01:55 AM #10thynaks for the reply sirs...one more question nid pa po ba irewire yung oto pag swap ng sr20de??
Discover the ultimate in relaxed romance with the best casual dating platform! Authentic Ladies ...
Exemplary Сasual Dating - Verified Damsels
