Results 1 to 7 of 7
- Dec 2012
- 1
December 28th, 2012 02:31 PM #1i got automatic nissan serena 2002, the problem is, it doesnt shift smoothly. When I put the lever to D or R, it does not move immediately. It also over rev before shifting to 2nd or 3rd and it moves very hard at low gear specially uphill, it also take a pause before shifting. And the worst part every time I stop at intersection, when step on the pedal it doesnt move just like the gear changed to neutral, it also happens when i slow down on turns.
I just changed the fluid 3 weeks ago, levels are good.
My mechanic says, it's a faulty MAF Sensor. I just need a clever opinion before changing anything because I just found out that my auto man is trying to rip me off by contacting the parts dealer.
Sorry for the bad english, lol
December 30th, 2012 01:45 PM #2
It's the transmission. A MAF sensor problem is usually related to idling and power issues as this measures the air intake flow.
If you drained the and filled the transmission before, try to do a a/t dialysis first where the entire system is flushed. If it doesn't go away then you may have to bring down the transmission.
http://tsikot.com/forums/transmissio...process-79697/
- May 2014
- 4
- May 2014
- 4
May 24th, 2014 04:41 AM #4Guyz tanong ko lang Saan ba may mura pa buffing? Meron kc dito sa Amin 2k ang singil pero ako pa bibili ng gagamitin like wax, and etc. pasay po location ko. Paki reply nalang sa may alam tnx much... :-)
May 24th, 2014 05:34 AM #5
- May 2014
- 4
- Dec 2015
- 4
December 28th, 2015 07:30 PM #7i know na old tread na po ito. but nag se-search ako ng problem with nissan serena tranny,
i also have nissan serena largo cd20, same problem here.
kkapalit ko pa lang po ng transmission dahil ayaw mag engage ng dati kong transmission
and now, bago na transmission ko nabili ko na surplus from Big Valve sa blumintrit
pero may problem na naman ule ako,
high revolution sya bago mag shift sa 2nd gear
noong i check ko after ang ATF after 1 day na ma install namin ang surplus tranny, dark brown a or halos malapit na mag black ang kulay, take note kakapalit ko pa lng. kaya na decide ako na mag change ATF ule. after 30 mints driving. black na naman ang kulay at high revolution bago ule mag shift ng gear
my question is
1: Bakit kaya nag iiba agad ang kulay ng ATF ko after 30 mints?
2: High Revolution sya, slipping po ba ito?
ang laki na kase ng nagagastos ko eh.
Monk-owned R53
