Results 21 to 29 of 29
- Feb 2015
- 5
February 8th, 2015 01:12 AM #21Sir pag binuksan ba yung radiator cover tapos lumalabas yun tubig instead parang hinigop possible water pump issue din? kakabili ko lng kasi ng 1992 eccs. Pansin ko pag start ko kahit sa morning kahit 10 mins palang syang umaandar around 75 degress na yung needle nya. diko alam kung normal lang to sa eccs or may problem na.
- 52,731
February 8th, 2015 09:12 AM #22the temp needle normally shouldn't go beyond the halfway mark.
if it does, either you're in very heavy traffic on a hot day, or there's something wrong with your engine cooling system.
- Feb 2015
- 5
February 8th, 2015 10:32 AM #23
- 52,731
February 8th, 2015 11:48 AM #24just the usual suspects...
1. clogged radiator.
2. weak water pump.
3. aux fans slowing down. (you should see just how strong the wind is with a new fan.)
3a. defective or wrong electrical connections to the fans.
4. thermostat stuck to "close or barely opens". (ugh!)
5. you have a leak! (it's not easy to see the leaking water pump, as it is hidden by so many things..)
and sorry, my only knowledge of imus, is that it is on the way to dasmarinas..
2. weak water pump.
February 8th, 2015 11:50 AM #25
loose compression na yan sir... or may singaw na cylinder head mo..
yung pag buga ng tubig sa radiator means... may singaw na cylinder head mo.. at dun na lumalabas ang pressure..
- Feb 2015
- 5
February 8th, 2015 10:36 PM #26
- Feb 2015
- 5
February 8th, 2015 10:39 PM #27Sir nung kinuha ko kasi to bagong baba lang makina. Nag uusuok daw kaya pinaoverhaul. Pag loose compression sir mas malala ba gastusin dun?
- May 2015
- 16
May 26th, 2015 12:20 PM #28Regarding this case, ano mas ok sa older cars? Mix water and coolant or coolant lang talaga?
May 26th, 2015 12:54 PM #29
still the mix of coolant and distilled water. masyadong matapang ang concentrated coolant, imho.
or you can buy the premixed already.
Looks like TGPH silently edited the article and removed the entry for Velocita Motors/Ferrari.
Car Sales Data (2024)
