Results 11 to 16 of 16
August 19th, 2009 08:40 PM #11
i own a B14. ticking sound lang ba? not yung parang jeepney engine sound? kung yung latter, its the tensioner guide. i have already replaced it na din sa B14 ko. cost is 3k, parts and labor na. imho, pwedeng i-DIY pero madugo. and you do not need a timing chain replacement, unless its out of shape na din, which is very unlikely. kung ticking lang, tama yung sabi ni woohoo.
- Aug 2009
- 7
August 20th, 2009 12:07 AM #12Baka hindi timing chain yan Sir, got the same issue before, di ko lang alam kung magkaiba definition natin ng ticking sound, pero mine was found to be just the metal covering sa may middle part na connected sa exhaust, di ko alam eksaktong tawag eh pero nasa may ilalim siya almost just below the engine mejo sa ilalim between engine and dashboard. Masyado kasi tricky yung sound kasi normally sa hood mo siya papakinggan para iinspect and since nandun siya sa side na un, most will think na timing chain yung tumutunog kasi halos pareho lang talaga, when in fact baka loose metal covering lang na pwede namang tanggalin without any effect. Try mo kaya ipacheck sa mga gumagawa ng tambutso, malalaman naman nila agad yung sa isang silip lang, mas maririnig din nila talaga kung dun nga kasi sa ilalim nila papakinggan yung tunog. Suggestion lang po, malay lang natin, baka po pareho lang tayo ng naging prob, it might save you a lot.
August 28th, 2009 03:16 PM #13
Many Thanks for your INFO guys..
I will have it check today at AEROHEAD AUTO SHOP para sure narin hirap kasi baka bigla magbreakdown pag kasama ko mga kids ko..a friend of mine recommend this shop oks daw trabaho and price...located daw sa 10th ave Caloocan
will update you guys..many thanks again
regards...
September 2nd, 2009 04:12 PM #14
update lang guys..
ok na.. super tahimik na ung engine..AEROHEAD replaced upper and lower TENSIONER oem na ginamit nila,,then tune up and timing..oks na pati hatak
thanks for all your inputs
regards,
marvin
September 12th, 2009 06:09 PM #15
Sir magkakano po lahat nagastos ninyo? Same din kasi yung sentra ko nung nagchangeoil ako biglang may tunog na parang sa diesel pakiramdam ko sa timing chain din yun e.
thanks po.
- Sep 2009
- 1
October 2nd, 2009 08:37 PM #16Sir magkano na gastos nyo for upper and lower tensioner. Same problem with my car. Started the annoying sound after I replaced the upper chain tensioner due to ticking sound nga but after all the diesel engine sound started during startup but after 5sec back to normal sound. I already done the change oil, same problem parin. I think i need also to replace lower tensioner.
Burberry Men Leather Jacket oskarjacket
Verifpro - paypal, ebay, banks, crypto, docs and...
