Results 31 to 40 of 53
- 52,731
May 19th, 2015 02:46 AM #31- - - - - - - - - - - - - - - - - - - - - -
yung akin, 1997 with ECCS, has an air bleed screw that i can play with, to avoid sudden low rpm engine shutdown.. the next models, i am told, hindi na raw..
this control is a big (gray) plastic recessed screw head (+ or phillips-like), somewhere under the air cleaner housing. it is seen from the right side of the car.Last edited by dr. d; May 19th, 2015 at 02:52 AM.
- May 2015
- 19
May 19th, 2015 02:52 AM #32
- Jun 2008
- 9
May 26th, 2015 03:31 PM #33pasingit po.
ask ko lng po kung san sa bacoor ung shop at may pasilip lang din po ako sa nissan sentra ko po. ito naman ang drama nya:
Maganda naman po menor nya kaya lng pag ne rev mo na cya parang inuubo na cya. at pag takbo naman, kumakadyot kadyot cya.
at ask ko lang din kung ano posible koneksyon nun sa aircon ko. sa una kasi aandar ang aircon at malamig cya in fairness, after ilang idle, nawawala na at d n umiikot umi engage ang clutch. lahat ng electrical ginawa na ng aircon technician nung pinalinis ang aircon at ang akala ko kasi needs cleaning lang ung aircon.
Plsea advice & thanks po sa sasagot
- May 2015
- 19
May 27th, 2015 08:19 AM #34Yung mekaniko na naka resolve nung Nissan problems ko sa Caltex Bacoor bago mag Puregold. May shop rin sya sa Angela sa Las Pinas if taga dun ka. Dick yung pangalan nya. Number nya 09234142710
Kumakadyot kadyot din yung Nissan namin. Lininis nya lang lahat ng kelangang linisin tapos pinalitan yung air filter and fuel filter. Papalitan din dapat yung distributor cap kaso walang mabilhan sa ATCO kaya pending muna yun. Di na sya kumakadyot kadyot after nyang tingnan at ayusin. Yung menor na lang at aircon ang kelangan kong ipatingin
- Sep 2015
- 21
September 27th, 2015 08:08 PM #35Mga sir need your help.planning to buy a nissan sentra lec ps 1998 for 89k.makinis p sya.ok po b ang price
September 27th, 2015 08:26 PM #36
- Sep 2015
- 21
- Sep 2015
- 21
September 27th, 2015 09:17 PM #39
do not judge a book by its cover. for an old car. the seller will try to sell by its looks.
quick checklist.
-engine(belts pulleys spark plugs coolant. ). last oil change? fuel filter changed? check for cracks in the exhaust manifold, engine mounts ok?
-check the chassis for rust, for an old car there could be some really bad rust. this could be the deal breaker.
-last transmission oil change?
-suspension and brakes- tanggal gulong and open the drum brakes, also brake pads.
-battery test also. baka kailangan palitan. if you know the price of the battery baka masurprise ka.
-test drive.
all your "findings" will require deduction from the sellers price.
quick checklist.
-test drive.
- Sep 2015
- 21
I guess SMC has been doing a good job selling them
Car Sales Data (2024)
