Results 11 to 20 of 53
- Aug 2012
- 129
February 4th, 2013 01:12 PM #11Same yata kami ng issue ah, series 3 din ako. Pag apak ng gas tapos bibitawan ko kaagad, kumakalog din. Di naman nangyayari pag mabilis na takbo ng sasakyan. Pinalitan ko na air filter at pina check fuel filter, so malamang MAF din.
- May 2015
- 19
May 11th, 2015 09:13 PM #12Ganito problem ko sa Nissan ko. Sa akin naman pag takbo 70 kph to 80 kph kumakadyot. AT yung Nissan Series 3 namin at ayon sa mekaniko namin AT problem daw. Ayun pinalitan ang AT pero after 1 week kumakadyot pa rin. Linis MAF at throttle body. Ganun pa din. Nagpalit mekaniko na kami. Recommendation ng bago naming mekaniko linis distributor cap at palit fuel filter. Linisin din daw nya fuel tank at fuel injector. Nakakapikon na kaya di ko muna binabalik sa mekaniko
- 52,727
May 11th, 2015 11:08 PM #13- - - - - - - - - - - - - - - - - - - - - -
i am thinking misfire..
pull out the sparking plugs; inspect, clean and re-gap.. you can also replace them if you like.
inspect and clean the distributor also.
and see if the hi tension cables sparkle at night.
good luck.
... you replaced the AT..., on a say-so?? so tell us.. did the problem return immediately, or was there a week's respite?
- Jan 2014
- 101
May 12th, 2015 02:22 AM #14pacheck mo ang servo sa mekaniko, sakit na talaga ng nissan yang pakadyot-kadyot pag meron marumi sa isa sa mga sensor nya..........just back read the forums marami kang mapi-pick na same problem like yours.
- May 2015
- 19
May 14th, 2015 04:42 AM #161 week after replacing the AT kadyot ng kadyot na naman pag asa highway at 70 kph to 80 kph tapos bababa rev to 1.2k. Di na namin binalik dun sa mekanikong yun at nagpalit mekaniko na kami. Dumating na din sa point na namamatayan na kami ng makina. Yung instance na asa traffic ka tapos baba rev mo sa 400 tapos mamatay makina tapos after mga 5 seconds mag on uli
Nung nagpa carwash kami sa Caltex Bacoor may nakausap kaming tao na may Series 3 rin at medyo nag chikahan kami at nabanggit nya na may Series 3 rin sya and nagkaroon din sya ng similar problems. Ang ginawa daw nya distributor cap, fuel filter at linis ng hoses
Next week babalik kami dun sa bagong mekaniko at lilinisin distributor cap at papalitan fuel filter. Lilinisin din daw nya fuel tank at yung mga fuel injector
Actually, binebenta na namin ito at may willing namang bumili kaso ayaw pakawalan ng wife ko kasi gagamitin daw as spare pang sundo sundo sa mga bata
- May 2015
- 19
May 14th, 2015 04:44 AM #17
- Jan 2015
- 468
May 14th, 2015 04:47 AM #18
ayy, hindi ka nagpapalit ng fuel filter?
mukhang yung kadyot basic PMS lang napapalit ka pa ng AT gn wala sa oras.
ako sa sentra namin na series 3, every change oil ko, sabay sabay na oil filter, fuel filter, spark plugs at air Filter (- depende, pero most of the time kasama na)
- May 2015
- 19
May 14th, 2015 05:02 AM #192nd hand na namin nakuha ito tapos nagsama pa kami nung mekaniko at sya nagsabi na okay na bilhin namin. First namin ginawa nung nakuha namin ito ay change oil, clean aircon, change ATF, linis spark plugs at change brake pads. Nung medyo nagkaka problems na ayun palit AT, linis MAF, linis throttle body. Nung may problema pa rin palit mekaniko na kasi medyo napapagastos na kami. AT palang 20k na!
Ang gagawin nung bagong mekaniko linis distributo cap, palit fuel filter, linis fuel tank at linis nung mga fuel injector. Papatingin ko na din yung servo as per advise here. Nung nagpalinis MAF sabi nung luma naming mekaniko palit servo na din daw eh di na kami pumayag dun
Ano pa kayang mga checks kelangan gawin? Ma reresolve pa kaya itong problems ng Series 3 namin?
- Jan 2015
- 468
May 14th, 2015 06:19 AM #20Sa tingin ko, fuel filter pa lang solb na problema mo.
Hindi ka na sana nahpalit ng AT.
San ka ba located Sir.
I went with him at LTO's The Link satellite office nung nag-renew sya. We were given a number to...
