Results 1 to 10 of 14
- Nov 2011
- 19
November 17th, 2011 11:42 AM #1Mga tol..
Ask ko lang tunkol sa nissan series 3 ko. Pag umaga or pag malamig ang makina ko. ang ganda ng takbo ng makina ko. umaarankada kaagad pag tinatapakan ko ang gas. Madali ako nakaka accelerate. pero after 1 hour of driving or more. napapansin ko parang ang hirap ng bumilis ng sasakyan ko ang tagal bago makapag accelerate. Then parang nanginginig ng konti na ung makina pag naka stop sa intersection at aandar.... Nawawalan ng galit pag ni rev ko iba na tunog nya di katulad pag bagong paandar na galit ang makina ko pag ni rerev ko.
bagong tune up na sya pero ganun pa din... ung timing ok na din..
Help naman mga pre...
Salamat
November 17th, 2011 11:46 AM #2
Most probably after ng tune up mo ay umattend ng Anger Management course yung oto mo. Joke.
November 17th, 2011 12:21 PM #5
Kabitan mo ng Angry Bird sticker.
If that's the case, seems to be something caused as the engine heats up. Did you check the distributor if it gets hot?
- Jul 2011
- 399
November 17th, 2011 06:53 PM #7Does your engine thermostat still installed and functioning well?
What kind of sparks are you using? Are you sure its up to specs with the manufucturers recommendation?
When was the last time you change your high tension wire? High tension wires has a lifespan of 5 years max and the performance of your engine greatly depends on the electricity provided by the distrubutor and travels thru the high tension wire to your spark plugs
Daming possibilities, you need to norrow it down first.
- Nov 2011
- 19
November 18th, 2011 03:13 PM #8ok naman ung high tension wiretat thermostat... ung spark plug new ngk. ang suspect ko is ignition coil or maf sensor
- Jul 2011
- 399
November 18th, 2011 06:53 PM #9If may problem yun maf sensor dapat sa start up mo palang noticable na yun erratic idle and sometimes slow response.
Puede yun coil mismo, what you can do is try borrowing first a coil and replace it then drive around the metro.
November 19th, 2011 09:03 AM #10
some parts lose their effectiveness pag umiinit na, ignition coil at yong condenser. try replacing condenser, mura lang naman yon. yong coil, manghiram ka muna. i think, its either of the two. hope this help.
Burberry Men Leather Jacket oskarjacket
Verifpro - paypal, ebay, banks, crypto, docs and...
