Results 21 to 24 of 24
- Mar 2013
- 2
April 15th, 2013 01:45 PM #21Hi iam also sentra gs user, did you switch on you O/D? you can ruan at 80KPH 2 around 2Krpm, dependoing on road conditions. My problem is, it is hard to shift from P to R(vv). My horn also is not working because the plastic(color yellow) that separates the contacts is broken. I hope i can find a replacement, or they might change the whole steering cover(i hope not, wla budget
- May 2012
- 67
April 15th, 2013 10:42 PM #22I drive with the O/D on (i think that is when the indicator is not lit). Eversince lumabas sa casa, no problems came up.
Yung hirap magshift from P to R, na-experience ko na dati. The problem was traced to a defective tail light bulb. Apparently, sabi ng mechanic, may sensor na dapat naka apak sa preno to engage the gear. Not sure kung totoo yung reason na yun. Pero yung vv di ko pa na-experience.
April 16th, 2013 02:25 AM #23
Sir kailangan talaga aapak ka sa brakes para mag release un P shift to R, lock kasi un P, i dont think may problema yan normal po yan, O/D off naman if mataas un akyatan na dinadaanan then O/D on kapag patag na un daan like highway driving para less consume sa gas na din, remember kapag naka ilaw un O/D sa dashboard = naka off un, lagay nyo lang switch On lagi basta normal driving lang, wag po malilito
- May 2012
- 67
April 18th, 2013 07:17 PM #24
UK, Oz-wide JB74 fuel pump recall. Check Suzuki Ph for VINs affected. Sent from my SM-S901E...
Suzuki JIMNY [merged threads]
