Results 11 to 20 of 24
January 5th, 2013 11:00 AM #11
DONT bring it to Rapide. Again, DONT bring it to Rapide!
Just read the horror stories here * Tsikot.
Sent from my GT-P7310 using Tapatalk 2
- May 2012
- 67
January 5th, 2013 01:33 PM #12Galing nako sa casa mga sir. Quick visual inspections on the interior, engine bay and rotor discs made by a senior tech did not show signs of the unit being flooded. Although, the symptoms really do suggest that it was. Moreso when the IT Consult was not able to detect the sensors that it needs to connect to. He still did not discount the possibility that this is or isn't a flooded unit. He addedthat if needed this wa flooded, the owner exerted a good amount of effort and money to remove its visual signs. He recommends that a full electrical check-up be done, which will take days. He re-scheduled everything on Monday.
More updates to come. I will let you know.
- May 2012
- 67
January 5th, 2013 01:35 PM #13
- May 2012
- 67
January 5th, 2013 01:37 PM #14
January 6th, 2013 03:25 PM #15
Try to do first a diagnostic reading of your vehicle before starting on the repairs. It may be with Nissan or at any shop you are comfortable with.
The basics: MAF Cleaning, change filters, ATF dialysis, tune-up, change filters, etc should also be done. Try to have an electrician check your electrical/electronics as well to as why they aren' t working well. You Sentra is a 1.6L right? It shouldn't be sluggish from take-off if it's running well definitely.
For spark plugs, NGK BKR6E-11 should be fine... even copper ones (just change every 10,000kms).
- - - Updated - - -
January 6th, 2013 10:09 PM #16
Sounds like something is wrong with the shift solenoid. Does the transmission slur a lot? does it feel like it's slipping? or does it simply feel heavy? Could be that the transmission doesn't want to shift down into first.
- - - Updated - - -
January 7th, 2013 09:11 AM #17
- May 2012
- 67
January 7th, 2013 06:23 PM #18Sir vinj, you hit the plan head-on. The car was brought again to the casa this lunchtime and accdg to the head mechanic, the car might stay for a night or two at the casa for proper diagnosis. They will check the electricals, replace spark plugs, air filter and oils (transmission and engine). Yes sir, it has a 1.6L engine. Will provide updates by tomorrow. Thanks for your advise sir.
I brought it to UN Ave.
- May 2012
- 67
January 7th, 2013 06:30 PM #19Sir niky. Will ask them to tpcheck that tomorrow. It doesn't feel like the gears are slipping. It just feels heavy. Although, over the weekend, I sort of got the hang of it. I can now control the acceleration better. I also drove it to Laguna last Saturday. In order to get to 80kph, I had to step on the pedal and maintain an RPM of 3,500. I think this is unusual for a 1.6L engine. Anyway, will know by tomorrow. Will update you sirs. Thanks.
- May 2012
- 67
January 9th, 2013 06:57 AM #20This is an update. I took out my GS yesterday from the casa. Wala kasi akong gagamitin today. Buti at napakai-usapan yung casa to let me take it out for one day. Maganda na ang hatak. The technician said that all they did was cleaned the ECU. Apparently, wala silang pinalitan except that they cleaned the contacts. He confirms that the unit was not flooded. I will have to return the unit tomorrow for the airbag indicator lamp.
- - - Updated - - -
T badge premium... imagine a 1.4M car without cruise control... Sent from my Nokia 3210 using...
All New Toyota Corolla Cross
