Results 1 to 8 of 8
- Nov 2010
- 4
November 20th, 2010 01:38 AM #1sir help naman po any suggestions about sa ride ko.. kasi palyado po ung cylinder no.1 nya. pag tinatangal po ung high tension wire dun para wala pong epekto sa kotse ganun padin po ang tunog. bagong palit na din po ung hightension wire,bago ung sparkplug then kakatapos lang po ng top overhaul pero palyado padin.. what would be the cause kaya?? is someone of you encounter this problem? pa help naman po.. di kaya un sa distributor or sa distributor cap?
reply naman po sa may akakaalam. TIA
- Nov 2010
- 13
November 20th, 2010 07:26 AM #2Pereho pala tayo. Sa Kamuning ko na dinala yung sakin kasi di maayos ayos ng mekaniko yung nissan ko. 3500 labor nila plus materials. Aayusin nila yung cylinder mo at timing chain. Diyan lang yan.
- Nov 2010
- 4
November 20th, 2010 12:40 PM #3bossing saan banda sa kamuning may contact no ka ba sa kanila? o di kaya anong address po doon?
- Nov 2010
- 4
November 20th, 2010 07:20 PM #4mga guru's at master dyan pa help naman po.palyado kasi ang no.1 cylinder ko at takot ako gamitin kasi baka tumirik lang. baka ho may ma recommend kayong shop sa qc area na sure talagang maayos.
November 20th, 2010 07:48 PM #5
replace the distributorcap, and have a competent mechanic tune your engine. if replacing the cap does not do any good, try looking at the distributor itself. Also try interchanging the high tension wires, to determine if one of them is failing
- Aug 2010
- 1
November 28th, 2010 11:45 PM #6
- Dec 2010
- 1
December 4th, 2010 03:34 PM #7Hi Sir Markstein,
I wonder kung napaayos mo na ECCS mo? If ever paayos ko rin sa akin. Exactly the same symptoms: palyado sa idle at lalo na pag naka drive ang transmission.
No effect din pag tinatanggal high tension wire ng cyl #1 and also yung wire ng injector nya.
Na top overhaul din, palit spark plugs, high tension wires, cleaned MAF, AAC valve, and servo pero ganun padin.
HELP HELP ANYONE...... SAAN BA PWEDE PAGAWA ITO NA RELIABLE?
T H A N K S
December 4th, 2010 04:56 PM #8
Since you are asking for a reputable shop
in the QC area...
SPEEDLAB: http://www.speedlab.com.ph/contact.php
in Mandaluyong area...
SPEEDYFIX: http://www.speedyfixph.com/
Wala parin spare tyre?
2025 Nissan Kicks
