Results 11 to 18 of 18
- Apr 2010
- 97
April 9th, 2010 06:24 PM #11tama sir, sarap din feeling sa bulsa menus labor hehe. sana mekaniko nalang kinuha kong curso hehe
April 9th, 2010 06:39 PM #12
- Aug 2008
- 41
April 9th, 2010 07:14 PM #13tama si ghosthunter. mangyayari nyan every now and then mo kakalasin yung cable para lagyan ng wd40. try mo yung mga "singer" brand na pang makina, this should last a little bit longer. i also tried squeezing in grease through the small openings on the ends of the cable sleeve before, it worked fine with my FE until the day i sold it.
- Apr 2010
- 97
April 11th, 2010 10:32 AM #14sir napapansin ko nga medyo tumitigas nanaman yung clutch ko. grasa ata talaga ang nilalagay kaso ang hirap naman lagyan from end to end. try ko nalang uli singer oil kahiti disconnect ko nalang yung isang end sa engine siguro at dun ko nalang patuluin ng oil.
- Apr 2010
- 14
April 13th, 2010 12:26 AM #15same prob sa sentra series 3 namin ang tagal ko na pinagtyatyagaan to ill try to go sa mechaniko bkas to have it greased hopefully umayos..may effort talaga kasi yung clutch pag inapakan..i would like to try some sentras here in lp to see kng matigas din clutch nila..sana po may tumulong
April 13th, 2010 01:33 AM #16
what could be the problem naman po
mataas ang clutch 3/4 ang taas.. nakakangalay na
kapalit lang ng clutch disk
- Feb 2008
- 76
April 13th, 2010 02:24 PM #17* jansky, meron pong stopper screw sa pedal ng clutch don po adjust yong angle ng clutch then adjust nyo na po pati tension.:cheers2:
- Jun 2010
- 1
June 1st, 2010 12:14 AM #18
