Results 1 to 4 of 4
- Nov 2010
- 13
May 4th, 2011 08:45 AM #1Hi! Ask sana ako ng advises. I have a 1998 Nissan series4. Same kame ng fren ko pero sakin, mahina talaga ang lamig. Pinalinis ko na yung evaporator, tubes and condenser. Bagong karga ng freon but still mahina magpalamig. Wala namang singaw kasi di nagbabawas ng freon. Compressor kaya may problem dito? Pls Help. I could be reach at 0918-4700130 - Francis
May 4th, 2011 09:25 AM #2
Check your auxilliary fans sir. :D baka mahina ikot ng mga fans... Also have the thermostat checked baka nag loloko.
- 52,731
May 4th, 2011 01:53 PM #3i had the same problem. it turns out, i had two problems. first, i found out my aux fan was dying. had it replaced (no such thing as fix: it's a throw-away thing. and when one goes, the other isn't far behind... within a month..)). then, it was fine for 1 week, then ganun na naman. i tried to look for the sight glass which will tell you if you need freon recharge or not. it seems, nissan does not have a sight glass. you have to have the pressures checked using external gauges. bottomline, i needed a re-fill (after 14 years!). ok n uli: freezing cold..
May 4th, 2011 02:17 PM #4
pwedeng mahina na yung compressor or me problem sa fan..
kung yung compressor, dapat nakita nung nagkarga ng freon... yung fan naman, di naman basta checkd ng mga a/c technicians kasi they would pressume na ok pa yon...
in short, try to check your fans first before thinking that its a compressor issue na mas malaking gastos...
