Results 1 to 9 of 9
April 30th, 2007 06:40 AM #1
my safari 95 brake is having a trouble, tumitigas pedal, i already change the hoses from alternator to canister to hydro vac but still the same, hard brake, whats the next thing i should do, any suggestions
BANNED BANNED BANNED
- 3,790
April 30th, 2007 08:53 AM #3did you blead it yet? the basic problem of tumitigas ng brake is air bubbles trap in the brake line...kahit na ba hydraulic assisted yan, pag merun hangin sa linya hindi magpafunction ng tama yan.
May 1st, 2007 08:08 AM #4
ok i try to bleed it this morning, ill update after that and if not go to hydrovac. thanks
May 1st, 2007 01:27 PM #5
after bleeding.. sobra naman ngayon lambot ng brake as in wala break lusot brake nya....
May 1st, 2007 08:29 PM #6
i got it, the brake pedal must be continuously pressed while bleeding and pressed to the bottom while closing the knots. lambot na brake an my safari is now braking but i think i must upgrade my hydro vac brake to d5 or d7. my safari is already old, approximately 12 years in service with me and so far this is my only problem. not that bad. thanks wildthing & 4JGtootsie.
i do it my self. approximate expense P80.00 for prestone brake fluids, P27.00 for 1.5 liter coke for my assistant who did the pressing of the brake and P10.00 for tide bar for a dirty hands.
- 3,790
May 2nd, 2007 04:31 AM #7congrats, glad to be of help - i have been exposed to a lot of old cars kaya naexperience ko yung ganyan nuon...
an upgrade of the hydro vac is probably in order...specially that it is old din na naman.
May 2nd, 2007 09:18 AM #8
Yup, for peace of mind you can consider overhauling/replaceing the hydrovac.
May 2nd, 2007 09:29 AM #9
Also have the same problem on the W123, but the hydrovac is really shot. Ang hirap maghanap ng hydrovac nowadays.
Glad your problem got solved.
Monk-owned R53
