Results 1 to 8 of 8
November 12th, 2002 01:09 AM #1
how do you get a better ride on nissan p/ups mine is an ultra eagle..i heard they do something about the springs?...ano yun..babawasan o dagdag ng leaf spring?..i havent got a clue...
i installed old man emu..nagimprove pero di pa rin ako kuntento..
pareho lang naman ang frontier at eagle di ba..exept for the engine syempre at looks/interior...pero halos pareho naman yung ibang component niya?
- 400
November 12th, 2002 02:40 AM #2if you're looking to make the ride softer, it's taking a leaf away. bear in mind this will drastically reduce the load-bearing capacity of your car.
November 12th, 2002 08:07 AM #3
Ang pagkakaalam ko, babaliktarin po ang leaf spring para lumambot ang ride. But this will also reduce the loading capacity of your truck. :roll:
BANNED BANNED BANNED
- 126
November 12th, 2002 08:45 AM #4If you never really load up the pick-up, then you can have them remove one leaf spring.
Alternatively, you can install Load Plus (from trailmaster). Mga P2,800 yata. This actually might be a good idea if you remove one leaf spring. Since nabawasan ng leaf spring, eh, di dagdag ka ng leaf spring helper (which is what this Load Plus is). Available from Ride stores yata.
More expensive option is to replace the leaf spring with Old Man Emu, too. But that's about 19t to 20t for a set of two leaf springs.
Good luck.
--Alf
- 3,790
November 12th, 2002 08:52 AM #5In my frontier, I play with the tire pressure to have a softer ride. I can not remove a leaf spring because I need the carrying capacity. There is a certain pressure ng tire mo that you would find "soft" enough for your back and not bad enough for your tire wear.
November 12th, 2002 12:47 PM #6
wildthing, what's your tire pressure? front? rear? stocks ba tires mo? slmt.
November 12th, 2002 01:17 PM #7
pwedeng baligtarin yung isang eliptic leaf. hihina ang load pero koti lang.
antayin mo yung DIY project namin ni otep sa ride ni djerms :mrgreen:
FrankDrebin GuestNovember 12th, 2002 01:30 PM #8
ah parang sa L200 ko.
pag nalubak ng konti, KAAADYYYAANGGGG!
Wala namang kalampag. Or maybe hindi na OEM yung shock?
hhhmmmm....
Varta used as replacement battery in German cars ... but they cost double that of Motolite ... not...
