Page 17 of 18 FirstFirst ... 7131415161718 LastLast
Results 161 to 170 of 174
    Jul 2004
    #161
    Quote Originally Posted by Boy Torotot
    ah ok po sir, pwede pala yon.... try ko po yan. pero kulang pa ko ng dalawang bolts, yon muna hanapin ko...o meron na rin silang bolts available sa karplus?
    bro -- try mo tawagan sila. tel nos are: 8410470 / 8160828
    hanapin mo si ronnie. kung hindi man sa karplus, they will refer you to a nearby shop or some other mechanic friend of theirs lurking nearby waiting for a job
    happy hunting
    #162
    Quote Originally Posted by 111prez
    Boy Torotot -- bro, check this website: http://forum.patrol4wd.org/phpBB2/viewtopic.php?t=21
    may isang troll owner na nag complain ng rubbing at the rear ng 285/75R16 tires on a stock rim and suspension
    This is what it looks like when 285/75R16 tyres are fitted to standard Patrol rims when fully articulated.
    Adding a spacer to lower the bump stops or changing to a zero offset rim can stop this happening.
    Or just carry black touch up paint, its only cosmetic.
    never pa naman nagrub yung akin. baka naman nag sag na yung shocks nya?
    Signature
    Jul 2004
    #163
    bro -- malamang weak na yung shocks niya
    o, baka hindi kaya ng stock na shocks ang laki ng gulong?
    ano kaya?
    #164
    maaari, i had replaced my shocks to bilsteins before putting on 285/75R16 tires.
    Signature
    Jul 2004
    #165
    Boy Torotot -- bro, obserbahan mo nalang. sa tingin ko, okay naman siguro
    however, kung hindi talaga kaya ng shocks mo, palit ka nalang. si boybi naka bilstein. ako naka old man emu
    kung ayaw mo mag palit ng shocks, palit nalang tayo ng gulong, hehehehe
    ang akin ay 275 70R16 na pirelli scorpion AT, 5 pieces. bago rin. last month ko lang binili. kaya lang nung nag palit ako ng OME shocks and coil springs, nag mumukhang maliit tuloy ang gulong ko, hehehehe
    #166
    kapag hindi pwede kay Boy Torotot yung 285/75R16, palit nalang kayo ng gulong para hindi na magpalit ng shocks si Boy T
    Signature
    #167
    even if you change the shocks ganun pa rin yan. the springs may be weak na or check mo view from the back of the car if n a ka center ang gap of the tires on both sides. diba may bannga yan before?
    change springs na lang better ride pa , may second hand ako OME shocks and springs 3 months use lang binenta ang unit. inquire ko if avail pa. may bilsteins din na shocks second hand.
    Apr 2005
    #168
    sirs 111prez & boybi, ok yang suggestion nyo a..hehehe. pero in case magkaganon man...that's another excuse na mag-upgrade to Bilstein/OME
    sir arb, hindi po sa akin yong nasa picture. so far wala naman po akong nakikita o napapansin na rubbing. pero just in case, in the near future ay magkaganon....pa-pm na rin ng prices nung 2nd hand OME & Bilstein mo...kumbaga, i'll keep it in mind..
    Jul 2004
    #169
    HOO-YAH!
    Apr 2005
    #170
    sir boybi... question po about your spare tire. pinalitan mo rin ba yong spare tire mo ng 285/75R16 na size? if so, kasya ba dun sa provision sa likod..i mean hindi ba sagabal sa opening nung smaller rear door at hindi natatamaan yong body mismo or wiper? di ko pa kasi pinalitan yong spare tire ko since ayoko muna tanggalin yong spare tire cover(since di kasya ang bigger tire dun). di ko naman na-try pa-mount ng ganon size ng tire sa bridgetone fort nung nagpalit ako.
    ok pa naman sa ngayon since maganda naman tingnan yong tire cover, pero balak ko pag mag-long distance travel ako, papalitan ko spare tire ko ng same size sa installed na tires(285/75R16) just to be sure.
    yong pics kasi ng patrol mo on the other thread, naka tire cover ka pa...so i think the spare tire there is still your stock spare tire.
ano ok na tires para sa GU Patrol
