Results 11 to 20 of 37
- Feb 2008
- 325
August 14th, 2009 01:41 AM #11here are some things you can do to improve fuel consumption:
1. pa-tune up
2. make sure tires are properly inflated
3. be gentle on the gas pedal
4. weight reduction - tanggalin ang mga bagay na di naman importante/ ginagamit sa trunk
btw.. best way to check your fuel consumption is to:
1. fill your tank up (full tank).
2. set your trip meter to "0".
3. drive.
4. next time you fill-up (full tank again) take note of how many liters of gas is needed until your tank is full. you can use this info together with your trip meter's reading to compute your fuel consumption.
- Feb 2009
- 171
August 14th, 2009 01:51 AM #12Oo nga minsan gigil ako sa gas lalo na pag gusto ko ng acceleration. Lalo na pag naramdaman ko na nagshift na yung parang napaatras yung katawan ko sa upuan
My tires is at 30psi but shifted to 25 kasi masyado daw matigas ang 30. Parang ayaw ko ng 25 kasi parang umaalog yung sasakyan.
Weight reduction? wala po laman yung car baka siguro ako ang kailangan mag weight reduction hehe kulang sa lakad tinamad na kasi nasanay sa kotse
August 14th, 2009 09:26 AM #13
just have your car tuned-up. change spark plugs, change the fuel filter and air filter. also have your alignment checked.
August 14th, 2009 01:09 PM #14
25psi? no wonder malakas sa gas. Stick to 31-33 if you wanna save fuel. Hindi naman matigas yun, tama lang.
Check mo rin (Intake) Air filter baka barado na. That's usually the culprit most people forget.
If you drive fast, do as much coasting as much as possible. That's the secret in saving gas when driving an automatic. Dapat smooth ang driving, if you are too harsh with the accelerator, you'll end up wasting too much fuel.
Drive at top speed (if you can handle it) once in a while (to clean up the system).
August 14th, 2009 01:26 PM #15
sobrang lakas nga try mo yung tip ni blaksun sa pag check ng gas mileage
August 14th, 2009 03:38 PM #16
Geez... 25 psi? That's not only bad for fuel economy, it's bad for your tire's service life, as it stresses the sidewalls more. For 14-15" tires on the Sentra, 28-32 is your best bet... fill up to 32-35, and if it's too stiff for you, go back down to around 30.
For that year of Nissan, you need to clean out your MAF and throttlebody. You also need to check that the TPS is disconnected when you do any adjustments to the ignition timing, otherwise, it won't stick.
Also... how long is your trip? It's 16 kilometers, yes, but how many minutes? If it's still taking you one hour, despite being a short trip, then low speed driving and stop-and-go situations (traffic lights) are eating up your gas... though I'd expect you to at least get 6-7 km/l in a situation like that.
- Feb 2009
- 171
August 14th, 2009 04:06 PM #17
- Feb 2009
- 171
August 14th, 2009 04:22 PM #18So here is my plan.
Change oil: Shell helix plus 10w40 from castrol gts 20w50 (Havoline Energy if possible because of its viscosity rating)
Spark Plugs: NGK or Denso
Oil filter: VIC
Fuel Filter: VIC
Air Filter:
Radiator Flush: Pre-mixed
Camber and Wheel Alignment
Throttle valve assembly cleaning
Greasing
Change of drain plug and gasket
Ignition timing adjustment
Grounded Check
Brake check
ATF/brake fluid check
battery Check
Timing chain/belt check
tires at 30psi
Did i missed anything?
The trunk in clean. it only contains a jack, some tools, CCD, QD and MF cloth
thank you very much for all of the replies
August 14th, 2009 04:33 PM #19
August 14th, 2009 05:13 PM #20
45 minutes... thus, around 20-22 km/h average trip speed... best economy is if your average speed per trip is closest to 40-60 km/h. Your time indicates you spend a lot of time at stoplights. Still, you should be getting better economy if your car is in better condition.
Most fun way to calculate fuel economy? Weekend trip to Subic. Cruising at 80 km/h on the NLEX should ideally give you between 14-18 km/l on an automatic-equipped compact.
Ayos sumabay pa sa Greenbelt 1.
Makati CBD parking
