Results 131 to 140 of 381
February 8th, 2009 10:20 PM #131
I just thought of making a web forum for cefiro owners..
So I did... hehe...
http://cefiroclub.tk
please register their and feel free to discuss what you know about cefiro's their.
- Sep 2008
- 13
February 9th, 2009 02:20 PM #132non-vtec Re: All about Nissan Cefiro [merged threads]
try checking the coolant temperature sensor/s for loose connection. i believe there are two of them. you can check them by removing the front air intake.
richierich,
pls pm price for RH side of corner lamp. thanks!
for those who needs cefiro stock parts kindly click that link
thanks!
February 15th, 2009 07:22 PM #133
we have 17 registered members already..
cefiro A31, A32 and A33 owners are welcome to join us...
- Jan 2009
- 16
February 17th, 2009 06:58 PM #134Our car is a Nissan Cefiro 97 model (A-32). My problem is bigla na lang kami namatayan ng makina while driving (nasa street pa lang kami, so around 20-30kph pa lang takbo. Actually, we hadn't reached 500 meters yet when the engine suddenly died. And then it took us around 3 tries before the engine started. It happened three times na, although wala pang 20 times na nagagamit namin ang Cefiro since we acquired it. Ano po kaya ang problema nun?
Then, there are also instances na kapag inistart namin ang sasakyan, bigla na lang nag-uusok ng itim, although sa simula lang ang itim na usok at nawawala rin. But we're still worried, lalo na't medyo may amoy gas. ano po kaya ang problema nun?
Lastly, ano po ba ang recommended tire pressure ng Cefiro?
Thanks a lot.
February 21st, 2009 01:11 AM #135
i registered na pero i cant log in.... why??
question for the A/T cefiro it should have the Gear signs right? like D R N D4 and so on... the one i got has no signs on the gauges.. also my rpm needle is broken. any suggestions where to go and what to do? thanks
February 21st, 2009 08:55 AM #136
*condorhero / speednuts420 - hindi pa rin kayo makapagpost? anong message ang lumalabas and ano lang ang nakikita niyo when you sign in?
*condorhero - may madagdag ka pa bang info?when the car is running, do you hear/feel anything weird? anyway kamusta maintenance niyo? and ilan na more or less ang mileage?
anong size ng tires ang gamit mo? kung stock lang, 30psi is safe.
*speednuts420 - yung sa transmission mo, yep, meron. paanong wala - you see the letters pero walang light or wala both?
must be the cable- yung sa tachometer mo.
- Jan 2009
- 16
February 21st, 2009 10:31 AM #137
Wala namang weird na nararamdaman when the car is running. Ano po ba ang MOST USUAL na problema kapag umaandar e biglang namamatay ang makina (for an automatic car)? Basta nung namatay ang makina, mabagal pa lang takbo namin (20kph).
At yung problema nga rin sa pag-iistart, as i said may usok na itim sa unang start. Tapos mamamatay. Then start uli, may usok pa rin, until nawawala na habang umaandar na ang makina. Pero amoy gas ung usok. Kapag tumatakbo na ang makina, nawawala rin naman usok. Ano po kaya ang MOST USUAL na problema?
February 22nd, 2009 11:45 AM #138
baka fuel filter or battery. fuel filter kasi baka barado na so kailangan na palitan. Yung battery, baka kasi it's not holding charge na. Napapalitan niyo na ba?
Yung usok na itim - is it everytime you start the car or tuwing hardstarting siya? Kung tuwing hardstarting siya, most likely "nalunod" yung car sa gas sa kaka-apak everytime sinusubukan siyang start.
- Jan 2009
- 16
February 23rd, 2009 09:12 AM #140Kapag iniistart yung car saka siya nagkakaron ng usok na itim at amoy gas. Pero after ilang saglit, nawawala na rin ung usok na itim. Sabi naman ng tatay ko, hindi na naman niya tinatapakan ung gas. So ano kaya ang problema? Fuel filter? Air filter? Spark plug?
Tapos kahapon, ginamit uli ng tatay ko. Then yung pauwi na sila, nasa major road sila, nang biglang go signal na e bigla na lang namatay ang makina. It took him 3 tries bago nagstart uli. Ano kaya ang USUAL na problema kapag bigla na lang namamatay ang makina? Automatic ang cefiro namin ha (model 97)
Thanks M707.
My Mazda CX-30 when I drove it 2 weeks ago it has around 14v when I checked. Earlier before...
What is the Longest Life of your Car Battery?
