Results 981 to 990 of 998
- May 2014
- 1,318
July 27th, 2021 10:21 AM #981Had an odd issue this morning with my rpm gauge on the dash.
This morning when i drove it off, i noticed it wasn't dnt registering/counting idling rpm. So on idle, full stop, neutral. The dash showed 0 rpm.
When accelerating to shift "up" my rpm would normallu be around 2k rpm. And it wss just showing 1k rpm on the dash. So i am approximating the 'missing rpms not counted' is idling rpm.
After i parked and restarted, rpm gauge was behaving normally again. But during the whole 'ordeal' car was just behaving normally mechanically.
Owned the car for 7 years, only 36,700kms in the odo.
- Mar 2014
- 2,127
July 27th, 2021 10:24 AM #982
July 27th, 2021 01:48 PM #983
- May 2014
- 1,318
July 27th, 2021 03:33 PM #984Nope. Battery is still not showing any sign of a hard start at present. But am monitoring it as im the primary driver of the vehicle.
Is it a cause for concern? Related to the ecu/computer box by any chance? Find it weird that only the idling rpm was not included when measuring in the gauge.
- Mar 2014
- 2,127
July 27th, 2021 04:51 PM #985
- 52,731
July 27th, 2021 07:57 PM #986many years ago, i had a similar strange event, in my 1997 sentra ex (efi na).
one night, as i was driving, all the lights went off.
the engine continued running fine, however.
i did not know what the instruments were showing, as it was dark.
after about 20-30 seconds, everything went back to normal.
it did not occur again. i sold her some years later.
then we hear of the above kuwentos.
is the nissan ECU haunted?Last edited by dr. d; July 27th, 2021 at 08:38 PM.
- May 2014
- 1,318
July 27th, 2021 08:48 PM #987It is really odd. Never happened to any of our cars in the family ever. I expected if the rpm gauge is faulty, then it just swings wildly or just stays at 0. But this is ultra specific where the idling rpm is not being counted/registering with the gauge.
I'll have to email Nissan I guess to inquire what it could possibly be and if it something to be majorly concerned about as a starting symptom that can "progress".
I expected if it was wire damage (say rats gnawed it) then there would be no signal to the rpm gauge after repeated restarts.
So, assuming it is an issue somewhere in the box, could it be insects having "died" or living inside? Say ants? hehe!
That is my thought process because I had a wireless keyboard before that was having an intermittent input issue that progress till it just died completely and did not work even with new batteries. It never fell hard on the floor so it wasn't physical "trauma".
After ordering the replacement keyboard online I was wondering why the table it was on had some ants when there was no food anywhere. I killed them. Came back after 15 mins and there were again ants. I suspected I had an ant problem inside the keyboard. They just decided to live inside the keyboard but there was no crumbs inside and i even clean it with alcohol from time to time. But apparently the were living further down the keycaps on the logic board.
I set the keyboard down on the ceramic tile floor. Took out the Bayer Chalk Ant and Roach Killer and drew a chalk perimeter around the keyboard along the grout so there would be no escape.
I let it stay on the floor overnight. Next day, all the ants were dead on the chalk. Tried to put in batteries and the keyboard worked again. I kept it as a backup in case it happened again to my new keyboard, which it never did again. It was just one of those odd occurences. It was a literal Hail Mary move to decide to try and kill the ants because I really expected the keyboard to still not work after. I just wanted vengeance. hehe!
I'm suspecting possible ants on some logic board or some small insects that could have cause the "intermittent" signal. Suspect, not sure. Will have to ask Nissan but I won't bring it to casa for now.
- May 2014
- 1,318
August 11th, 2021 12:45 PM #988Happened again this morning. During a COLD START. So that might be one requirement. Another is more than 2 days of the car being unused/not started.
If it happens again, I'll have to bring it straight to Nissan for them to scan the vehicle. They basically have no idea what could be the cause or if it is a major concern or not.
- 52,731
August 11th, 2021 12:51 PM #989
- Jan 2008
- 4,726
August 11th, 2021 01:11 PM #990if you have OBD scanner, you can verify if there is "rpm" readout from the ECU.. if there is, the gauge might be faulty or some condensation got to it causing the faulty reading
if no rpm readout from the scanner, then possible issue with the rpm sensor.. (located in the flywheel or crank shaft)
