Are there locally available shocks that are similar to a Float XMR for Moto racing, here's the specs:
FEATURES/TECHNOLOGIES
- Ultra-lightweight (1.1 lbs * 10.25")- Velocity Sensitive Damping Control- Samurai Sealing System (SSS)- Self-adjust Air Negative Spring- Infinite Progressive Spring Rate- Internal Floating Piston (IFP)
ADJUSTMENTS
- Infinitely adjustable air spring- Air Volume Adjust (AVA) system- Wide-range rebound
Pwede kaya yung Monroe Air Shock? Ano specs nito, I can't find any dimensions sa net.![]()
