Page 1 of 2 12 LastLast
Results 1 to 20 of 23
    Aug 2007
    guys ano kaya mas ok pang trail, 2 stroke or 4 stroke?
    Quote Originally Posted by speedmaniac View Post
    although I am no two-wheeler, I would think 2 stroke because of the lighter overall weight of the bike.
    Nov 2007
    mas maganda ung 4 stoke tol....
    Jun 2006
    mas ok tol ang 4stroke, locally or imported trailbikes. sa fourstroke banayad ang takbo mo yung 2 stroke minsan pag di gamay lalo na sa mga steep inclines bigla na lang na bumabato(burst of power).
    4 stroke:
    pros: low FC
    predictable power
    no 2t oil to be mixed w/ petrol
    cons: higher maintenace(engine)
    slightly heavier
    more expensive
    2 stroke:
    pros: low maintenance(engine)
    less expensive
    lighter
    cons: higher FC
    mixing 2t oil
    sudden burst of power(advantageous to some)
    smoke stench
    Aug 2005
    Quote Originally Posted by cyrusblutrooper View Post
    4 stroke:
    pros: low FC
    predictable power
    slightly heavier
    more expensive
    2 stroke:
    less expensive
    lighter
    cons: higher FC
    mixing 2t oil
    smoke stench
    Malakas ang 2-stroke na makina kaysa sa 4-stroke pero di maganda ang emissions.
    mas malakas ang power ng 2t pero mahina ang torque
    Jun 2006
    Quote Originally Posted by sboogie View Post
    +1
    4t feel mo baon na baon ang tire sa track.
    2t feel mo parang naka lutang ang tire sa track.
    kung sa trail rides i recommend 4t.
    Sep 2006
    ano daw?
    Sep 2006
    the two important advantages of two-stroke over four stroke are: they are simpler and lighter, and they produce about twice as much power. disadvantages are: two-stroke engines don't last as long as four-stroke engines do since it has no dedicated lubrication thus wearing the engine faster, higher gas consumption, produce a lot of pollution.
    more disdavantages...pero kung pang-trailing...i would still go for two-stroke...
    4 stroke:
    pros: low FC
    predictable power
    slightly heavier
    more expensive
    2 stroke:
    less expensive
    lighter
    cons: higher FC
    mixing 2t oil
    smoke stench
    your right sir, ito lang po alam ko.
    2t is more powerful than 4t in terms of hell track
    2t smoke a lot due to 2t oil burned, unlike 4t
    2t is lighter than 4t
    2t high rev than 4t about 30% rpm def
    re trail riding i go for 4t, im currently using xrm 110 travel from Davao city to General santos city to davao city to cagayan de oro city v.v. sprocket ko lang ang may gasgas, about 850Km v.v ang layo at speed of 115kmh max-80kmh min..P900.00 ang fuel, not bad
    +1
    recomended ko rin ang four stroke 4t,meron kasi low end power na kailangan natin sa trail...yung gumagapang ba. paahon sa mga matatarik na bundok
    Oct 2007
    kailangan ko more than 4 strokes para labasan
    Quote Originally Posted by Ben Musong View Post
    Yes sir, we need more than 4stroke para labasan, labasan ng pawis due to high speed aquired from multiple stroke of ur engine, the more the better
    thank for the comment sir
    Aug 2007
    di ba pinagbabawal na ang 2 stroke dahil sa usok na binubuga nya.. hanggang ngayon pala legal pa din ito..
    Dec 2003
    2t ambaho na ng damit ko pag ka biyahe..
    4t feeling formal parin ako kahit papanu.. hehehe
    Oct 2007
    2 stroke - ayaw sa tubig4 stroke - okey lang sa tubignaalala ko nung tumirik ang 2stroke sa lakas ng ulan ang layo ng linakad ko pa uwi, minsan pag may pag iiwanan iniiwan ko lang, kaya nag sawa na din ako sa 2 stroke binigay ko sa tiyo ko at kumuha ako 4 stroke kahit malakas ang ulan okey pa din, limusong sa baha wag lang abutin ang intake ng air cleaner go pa din....yan ang 4stroke....
    Sep 2005
    4 stroke po...may napanood po ako about 2 stroke na nakakaapekto daw sa global warming ung usok dahil sa 2t oil na nilalagay kya LTFRB(correct me if im wrong) will assist tricycle driver with 2 stroke bike na makabili ng 4 stroke.
    Oct 2007
    sa health din delekado ito, anu-hin mo pa ang na save mo dahil low maintenance kung may lung cancer ka na........or ang mga anak mo...
    Dec 2004
    Mas ok 4t. Especially pag steep uphills. Sometimes mahirap mag pag 2t coz sobrang bilis mag accelerate. Anyways the new 4t engines power now are not like the old 4t engines before.
    2 stroke
2 stroke 0r 4 stroke?
