Results 31 to 40 of 40
September 5th, 2005 10:27 AM #31
I had a sort of similar problem before in my Adventure. Had the sort of 'clankclankclankclankclank" lalo na if it is in idling or when I'm in an incline. Pag accel. naman or pag tapak ng clutch nawawala. We later found out na may tama na pala ang muffler ko (yung the one right underneath the car, not the one at the end). Right inside I can hear that rattling noise. After pinalit wala na ang problem.
Tsikot Member Rank 3
- Apr 2004
- 663
September 27th, 2005 12:56 PM #32Just done with 30TKm PMS. They inspected transmission support and muffler hanger. According to my advisor, they tightened brace of the exhaust pipe assembly.
- Sep 2005
- 2
September 30th, 2005 11:37 AM #33When I had my eclipse I had the same rattling happening when I would drive and it would stop when I shifted or put in the clutch. I ended up needing my clutch replaced which is why I got rid of the car so you might need a new clutch.
- Apr 2004
- 663
October 4th, 2005 10:33 AM #34things seem ok so far.
update 10/11/05: hmmm, minsan bumabalik. so dinala ko ngayong umaga sa casa ulit. my advisor explains that the clutch spring is the culprit. not having it fixed will do no harm to the transimission, he says. normal lang daw... even the L200 has this. the release bearing still ok since it engages, he confirms too. if the rattle gets louder or doesn't go away even with the clutch disengage, have it looked at again. replacement of the spring is P3000 and normally it gets replaced with the clutch when milage is around 100T Km.
my plans? well, i think ipa-check ko nalang siguro every PMS para ma-monitor.Last edited by RafRaf; October 11th, 2005 at 10:55 AM.
- Oct 2005
- 317
October 14th, 2005 02:35 AM #35guys!!! walang problema transmission nyo,masyado pang maaga para bumigay yun. check your exhaust pipe masyado kasing mabigat ang resonator or silenser natin kya ganun.kaya karamihan nagmumufler nlng isa ako dun...
- Apr 2004
- 663
October 27th, 2005 01:56 PM #36This may be my last log here regarding this problem of mine. I wrote an e-mail to mitsubishi motors - d-doctor*mitsubishi-motors.com.ph - and asked them to confirm what my service advisor had explained to me. Is it really normal? Who does it seem that others don't have this problem? They sent an engineer (from Cainta) to check my complaint. We met in another Mitsu casa. Both the engineer from cainta and at the casa where we met (including the service/parts manager) had same analysis. That it was the torsion springs in the clutch disc that was causing the rattle. The engineer from cainta explained that there is an allowable play for the torsion springs in the clutch disc. Mine happens to have developed some play I suppose. When the machine is heated up, it probably has expanded to fit snuggly such that the noise goes away. But this shouldn't have negative effect on the machine - safety-wise and performance-wise, they explain. They also said that my problem and my vehicle have been noted and if any more bigger problems occur and traced to have been due to this clutch spring issue, that it will be covered under warranty. They seemed to be very confident about this that they even said that this will hold true even after the 3yrs/100TKm period. That's customer service for you! Thank you to the people from Mitsubishi who checked Seth today!
October 28th, 2005 03:56 PM #37Originally Posted by RafRaf
Hindi lang pla engine ng mitsu realible pati customer service.. hehehe
- Oct 2005
- 6
October 30th, 2005 06:09 PM #38ganyan din sakin kaso hinahayaan ko na lng...pag start sa una maingay, minsan meron minsan wala...
- Nov 2005
- 38
November 11th, 2005 11:57 AM #39Originally Posted by Shadetree MKNX
More reading to understand clutch-related chatter (or clatter) at AA1Car Automotive Diagnostic & Repair Help Online at <http://www.aa1car.com/library/2004/bf40459.htm>
Cheers!
- Oct 2009
- 2,271
January 16th, 2017 01:40 PM #40update ko lang itong thread na ito baka na solve nyo na ung clatter sount ng tranny nyo.sa aking 2008 nagpapalit na ako ng CD,PP,RB,PB,medyo humina ung clatter ,pero dinig parin kapag naka nuetral,maingay parin pero hindi na kasing lakas dati.ano pa kaya ibang problema nito..
sak nga pala kahapon ko lang napa gawa.pero ngayon medyo slide siya sa 3rd gear at 4th.normal lang kaya ito.or hayaan ko muna gamitin ko muna.baka sakaling lumapat pa ng husto ung clutch dics niya..
Suzuki JIMNY [merged threads]
