Results 41 to 50 of 85
January 8th, 2005 12:15 AM #41
mine Gen1 Paj A/T (Subic)
130 kph pero kaya pa...problema ko nag downshift yung A/T at this speed umaabot 5500 RPM! (so release pedal ako..parang sasabog makina eh).
Got to have my accelerator cable checked masyado yata adjustment.
I did washer mod pala. Also had carbon clean done at Betan 6 months ago.
Try nyo din Bio Diesel.
Tsikot Member Rank 4
- Oct 2004
- 2,315
January 10th, 2005 11:46 PM #43pano ba yan washer mod na yan? May thread na ba nito? Curious lang po. Pwede ba ito sa ibang sasakyan?
January 11th, 2005 04:19 AM #44
akin 2.5 gen.. 170 kph sa skyway.. manual pala... walang aircon... todo na... 4K rpm
- Aug 2004
- 223
January 12th, 2005 09:44 AM #47
the pajero is not really meant for high speed cruising.
1) gearing ratio meant for low-rev high torque performance
2) optimal torque is already reached at 2,800rpm - 3,000 rpm
3) high center of gravity
4) high wind drag coefficient being an SUV/squarish in design etc...
In my case, I have already maxed boost of my 4M40 to 12psi, used open type air filter, replaced all intercooler and exhaust plumbing, about to install a water injection induction system in the intercooler, used 10% blend biodiesel --- but was just able to top out at 150kph at the North Expressway!!!
January 12th, 2005 10:40 AM #48
no mods.. dati un may nilalagay sa fuel na parang booster ata un.. lage hinahaluan dati ng uncle ko... pero nun umabot ng 170 kph hirap na hirap na ah..hehehe.. parang umiiyak na un makina... downhill na un.. hinde siya un stable.. bumababa agad un speed
January 12th, 2005 11:57 AM #49
This topic challenged me to step harder on my Pajero accelerator. The best I could get was 135kph (A/C, Stereo, Headlight On) this morning along the sucat-alabang stretch (SLEX). Di na kaya ng dibdib ko (but I could go 160 for my civic) or could be worried with speed limit violation. All stock for my 2.8L A/T fieldmaster. Woodfire: 1) How would you able to get 12 PSI boost, who could measure this?
January 12th, 2005 12:27 PM #50Originally Posted by Field Master
1) Install a manual boost controller; 2) Install a boost guage (analogue would suffice)
But at the end of the day, your cruising speed will be severely limited by the pajero's gearing ratio (differential ring & pinion).
Has anyone of you tried buying or installing front bumper that's made in taiwan (yung...
